5 speed conversion option
#12144
05/22/04 01:46 PM
05/22/04 01:46 PM
Quite a few people have expressed interest on how I did the 5 speed conversion in our garage chally (RIP). Well I finally got enough time to get some info for you lovely people.
Items needed:
-T-5 tranny (mustang, transmaro, etc...)
-Driveshaft from that tranny
-Lakewood scatter shield (or regualr bellhousing and a call to drdiff)
-Transmission mount from your car and the T-5 car
-MIG or TIG welder access
-Your correct flywheel for your motor (mopar)
-Your correct pressure plate (mopar)
-A clutch for a T-5 tranny
-A pilot bushing with an inside diameter correct for tanny and oudside diameter correct for your motor
-Mopar Z-bar
-1 inch plate steel
I would expect your car to be down a week or so depending on how much you work
With the T-5 out of a Mustang your shifter ends up kiddy corner of the stock (4-speed) location. So it looks better on Automatic cars.
Re: 5 speed conversion option
#12146
05/22/04 01:48 PM
05/22/04 01:48 PM
#12147
05/22/04 01:56 PM
05/22/04 01:56 PM
Posts: 8,016 Polson, MT
DoctorDiff
Polson, MT
What is the stick out length of the Ford input shaft compared to the Mopar 4-speed unit?
[Re: DoctorDiff]
#12148
05/22/04 01:57 PM
05/22/04 01:57 PM
Fairly close after the tranny is mounted to the bellhousing
#12149
05/24/04 06:25 PM
05/24/04 06:25 PM
#12151
05/24/04 06:59 PM
05/24/04 06:59 PM
Posts: 2,287 Amarillo, Texas
65Dart270
Amarillo, Texas
ratstar, how different is the shifter location compared to factory humps? If a car did not have the factory hump, would it be easier to fab up an opening for the shifter, or use a factory Mopar 4 spd hump?
"Although prepared for martyrdom, I preferred that it be postponed." Sir Winston Churchill
[Re: AlexP]
#12153
05/24/04 07:16 PM
05/24/04 07:16 PM
Alex to answer your questions the tranny ount just took a little bit of time. If you took more I am sure you could make it look alot better than mine. The clutch was a 10.5 but we used everything else 11. It works.
Shifter location in a b-body would be i believe tha same as it looks in the e-body. All I know is that the put the shifting location directly in line with the tranny center instead of off to the left side like the 833. It would be easier and better looking not to have a 4-speed hump.
[Re: AlexP]
#12155
05/24/04 07:43 PM
05/24/04 07:43 PM
I am sure they make a 1350 version of it, and I have no idea on if they are different for a ferd or gm. Good thing to look into though.
[Re: Dart360sav]
#12162
05/28/04 07:05 PM
05/28/04 07:05 PM
Stock clutch fork yes but modified slightly. Very slightly. It has to be slit and welded. Just to create more of a bend.
Cost for us was about $200. But thats only cause we do all the fab work and the tranny was only 60 from a friend. Havent priced them in the j-yards.
You have to fab an adapter from the tranny to the housing, thats what the 1 inch steel is for.
It was done on a smallblock in a chally.
I have heard that the 6 speed is close but I havent gotten my hands on one, yet.
#12163
05/28/04 07:58 PM
05/28/04 07:58 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
mcleod is in the process of making blowsheilds that are compatible with the newer 5 and 6 speeds ,they may be already available
