bb 727 applacation #1215855
04/14/12 10:53 PM
04/14/12 10:53 PM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
what was this trany used in 2801541 ?
2272-0017 ?
thank you !
Re: bb 727 applacation [Re: calrobb2000] #1215856
04/15/12 01:16 AM
04/15/12 01:16 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
1967-68 440 high performance. if it's original it should have (i believe) 4 pinion planets front and rear, small pin two spring front servo and may have the HD input and output shafts. to identify the HD shafts the input would have a small groove cut in the converter splines and have yellow paint dabs, the output will have darker heat treating and yellow paint dabs on the yoke splines. imho a good core to start with if it's original.
