any pics of a crank girdle? #1215553
04/14/12 01:17 AM
04/14/12 01:17 AM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
heard these are a must for a 440 reving around 6000 rpm.....hughes engines has a real good one so i'm told
Re: any pics of a crank girdle? [Re: CUDA8U] #1215554
04/14/12 02:04 AM
04/14/12 02:04 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
We turned a 500 inch B1 7200rpm without any problems with a stock block fitted with ARP main studs without a girdle.
It made over 300 passes till the timing belt broke
Re: any pics of a crank girdle? [Re: CUDA8U] #1215555
04/14/12 08:30 AM
04/14/12 08:30 AM
Andrews,In. U.S.of A.
67_Satellite Offline
At that level, stud the mains,maybe throw in some lighter pistons and new rod bolts,and go have fun with it.
Re: any pics of a crank girdle? [Re: CUDA8U] #1215556
04/14/12 01:04 PM
04/14/12 01:04 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
not necessary at all for that engine and imho a questionable idea for just about anything else. if you're making that much steam a better block is the correct "fix"
Re: any pics of a crank girdle? [Re: jamesc] #1215557
04/14/12 01:05 PM
04/14/12 01:05 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Re: any pics of a crank girdle? [Re: JohnRR] #1215558
04/14/12 01:18 PM
04/14/12 01:18 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
this was suggested from a guy who has raced mopars for 27 yrs. so i have to believe he might have a reason to suggest it.Everything he has suggested about the tuning on my 440 has been bang on.I just like to have several opinions before i make any decision.He explained that with higher revs he has had crank caps loosen off slightly on his 440 and said this girdle is just a little more insurance.
Re: any pics of a crank girdle? [Re: CUDA8U] #1215559
04/15/12 02:01 AM
04/15/12 02:01 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
here is the bcr girdle kit
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
