Re: Power Glide install??
[Re: HEMIFRED]
#1215140
04/17/12 01:50 PM
04/17/12 01:50 PM
Posts: 40 Harrison Township, Michigan
Hemi SS
They can no longer be recerted. I used the TCI adapter for a few years with no real issues, except when I went to remove the adapter plate, the countersunk bolts with the hex-drive head were seized up and the hex hole stripped out. Had to weld nuts onto them to get them out. I now use the JW Wheel and also their bell. I do have a little trouble with the starter mounting holes having pretty loose threads.
Did your studs strip also.They use the fluted spline like those that come thru a rear housing and the chunk slides on them. mine just wore out and turned whenj tightened. now using the 1/2" plate the studs are tapped and secure
After reading this I decided to go with the Reid bell and case. It looks like the starter screws are tapped thru on it. Where did you find the Reid billet flexplate? I couldn't find it on their website.
