Question for original A-body 4-speed owners #121503
09/15/08 09:54 PM
09/15/08 09:54 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
The frame crossmember on my 70 Dart which is an original 4-speed car has metal cut out of it (very roughly) where the shifter rods pass over it right next to where the trans. crossmember mounts. I was telling a guy I know at the body shop I use about it (who owns a Duster) and he said his car was the same way when he got it. But a friend of mine who also owns a 70 Duster has a crossmember that is not cut. Another friend of mine was telling me he has seen this before. He and I were discussing the possibility of this being done at the factory or if people just cut them through the years to accommodate aftermarket shifters. I'm just curious as to whether or not owners of other original 4-speed A-bodys have crossmembers that have been cut where the shifter rods pass over it.
Re: Question for original A-body 4-speed owners [Re: 6PAX] #121504
09/15/08 10:04 PM
09/15/08 10:04 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
We've had many 4-speed A-body cars and none have ever had the crossmember cut.I suspect it because of either a cheap aftermarket shifter install or using another body line shifter assy.
Nautilus Racing-
Re: Question for original A-body 4-speed owners [Re: Chris2581] #121505
09/16/08 12:03 AM
09/16/08 12:03 AM
Ashburn, Virginia
ashburnmike Offline
ashburnmike  Offline
Ashburn, Virginia
My 70 Swinger 340 4-spd is original and shows no signs of being cut at all.
Re: Question for original A-body 4-speed owners [Re: ashburnmike] #121506
09/16/08 12:18 AM
09/16/08 12:18 AM
Montana
P
Posest Offline
Posest  Offline
P
Montana
My 72 340 demon has not been cut on.
Re: Question for original A-body 4-speed owners [Re: Posest] #121507
09/16/08 08:08 AM
09/16/08 08:08 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
I think we need a picture.
Re: Question for original A-body 4-speed owners [Re: ashburnmike] #121508
09/16/08 08:19 AM
09/16/08 08:19 AM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Mine as well, exactly as above.
Re: Question for original A-body 4-speed owners [Re: 6PAX] #121509
09/16/08 08:38 AM
09/16/08 08:38 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I took a 4 speed hump out of a Duster back in the late 70's/early 80's, can't remember year , but the torsion bar Xmember was cut out where the shift rods were , it was done at the factory best I could tell .
Re: Question for original A-body 4-speed owners [Re: JohnRR] #121510
09/16/08 12:27 PM
09/16/08 12:27 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Neither torsion bar or trans crossmember are cut on my 70 Dart.
Re: Question for original A-body 4-speed owners [Re: RobX4406] #121511
09/16/08 01:01 PM
09/16/08 01:01 PM
arizona
V
VPrace Offline
VPrace  Offline
V
arizona
I just cut up an original 65 dart and the t-bar crossmember had metal removed! factory 4 spd w hurst shifter
Re: Question for original A-body 4-speed owners [Re: VPrace] #121512
09/16/08 01:08 PM
09/16/08 01:08 PM
RobX4406 Offline
RobX4406  Offline
Very different from the 67 and up A's. OP has a 70 A body.
Re: Question for original A-body 4-speed owners [Re: 6PAX] #121513
09/16/08 05:15 PM
09/16/08 05:15 PM
North Bay On.
mrdodge69 Offline
super gas
mrdodge69  Offline
super gas
North Bay On.
Nothing cut up on my 69 Dart
Re: Question for original A-body 4-speed owners [Re: mrdodge69] #121514
09/16/08 09:11 PM
09/16/08 09:11 PM
St.Clair Shores, Mich
bryansgarage Offline
I would think that as long as you "cap" the crossmember with 1/8 plate steel, then it would still be strong.
