Small block back #1214948
04/12/12 06:00 PM
04/12/12 06:00 PM
Abilene,Texas
ram87 Offline OP
ram87  Offline OP
Abilene,Texas
Just picked up my small block 340 + .030 from the machine shop after a year and a half. It's a 340 and going together with Carillo rods, Ross pistons, Isky ground .660 lift roller cam, Erson 1.6 roller rocker arms, Batten aluminum W2 heads (mega port and polish), Indy 360-3 intake. Should be at least 14:1 compression ratio. Want to get it together and in my little Dakota so I can run it one time before I get rid of everything. Strip here is closed and doesn't look like anybody has the coins to buy it. I am too old to do a lot of towing so I will be finished if I can make just one pass in the little truck.
Re: Small block back [Re: ram87] #1214949
04/12/12 06:27 PM
04/12/12 06:27 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Hey Lynn glad to here your getting things back together! It sucks that Abilene is currently closed. Maybe you could make it to wichitaracewaypark.com , texasraceway.com or desertthunderraceway.com.I hope your doing well! I've heard that Sterling VW might go after abilene next year we all hope so.Hope to see you around in the fall when I can get back to some racing.
Re: Small block back [Re: DavidDean] #1214950
04/12/12 07:32 PM
04/12/12 07:32 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Nice looking truck. Good-luck when you make it out and if you get a chance please post some more pictures.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
