Edelbrock carb & kickdown throttle cable ant right??? #1214287
04/11/12 08:04 PM
04/11/12 08:04 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
My edelbrock kickdown & throttle cable stell ant right, if I drive with a lead foot, it douse fine, but if I pull out slow, it don't seem too smooth, so I would like to see some pics of how you guys with a-bodys have got your kickdown & throttle cable set up!
hears a pic of how mine is set up!
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: Hoop] #1214288
04/11/12 08:34 PM
04/11/12 08:34 PM
North Dakota
440abody Offline
440abody  Offline
North Dakota
There are a couple of ways to approach this. One: it looks like you have a factory kick-down set up. Find yourself a factory service manual and adjust the linkage properly. But the linkage on the transmisson, and the carb need to have the proper throw ratio to be able to work together. If you have a lever on the transmission from a van, and the one from your a-body on the carb for example the throw ratio will not be correct, and getting it to work can be a real challenge. Or option two:Call Bouchillion Performance and order their kick-down kit and fix the problem for good.
73 Dart Swinger 440/727 8.75 w/3.55's
34 Ford 3w coupe with a soon to be 1958 392HEMI!
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: 440abody] #1214289
04/11/12 08:47 PM
04/11/12 08:47 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Can't tell, it does not look like you have the linkage adapter from Edelbrock on your carb, if you don't have it, the geometry will be wrong.
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: 440abody] #1214290
04/11/12 08:56 PM
04/11/12 08:56 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
I do have Edelbrock Throttle Lever Adapter thats not on it, but don't see how it all would hook up, so if someone is running that setup, pics would help!...& I would like to see pics of the other ways you guys have it setup!
http://www.ebay.com/itm/Edelbrock-1481-T...830&vxp=mtr
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: Lee446] #1214291
04/11/12 08:57 PM
04/11/12 08:57 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
winner, looks like it might be a 2bbl kick down setup too
Don't be the exception.
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: Supercuda] #1214292
04/13/12 02:28 PM
04/13/12 02:28 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
I would say it is too, do you think I might ort to tray to find a 4bbl small block setup?
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: Hoop] #1214293
04/13/12 02:31 PM
04/13/12 02:31 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Here is a picture I stole from another
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: Hoop] #1214294
04/13/12 02:49 PM
04/13/12 02:49 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
One post per problem please.
I have no idea what my bracket was for originally, but I made it work.
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: JohnRR] #1214295
04/13/12 03:00 PM
04/13/12 03:00 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
Mmm, I'm thinkin the stude should be aginst the back of the kick down, because with my old set up it was smooth & good for everday driven for 7 years like that, but I was not geting full throttle!
hears a pic of my old setup!
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: JohnRR] #1214296
04/13/12 03:16 PM
04/13/12 03:16 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
Challenger 1, I don't know if johnRR or who broght up one of my old post from last year, but this is the new one!
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: Hoop] #1214297
04/13/12 03:19 PM
04/13/12 03:19 PM
hooziewhatsit Offline
Yep, you'll want to get the correct edelbrock adapter.
And, the slot in the kickdown MUST be held against the throttle studs at all times (by that long spring). If you have a gap there right now, that's your problem.
When you push the throttle open, the lever must move immediately with it. The long slot is so if the kickdown linkage binds up, the throttle can still close (before things get exciting ).
When I did my 4bbl conversion I had to extend the linkage about an inch so I had enough adjustment to keep it against the throttle stud.
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: Hoop] #1214298
04/13/12 03:46 PM
04/13/12 03:46 PM
Cincinnati, Ohio
Cincinnati, Ohio
I did not look at the dates, my bad. I hope you get it squared away this time.
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: Hoop] #1214299
04/13/12 04:52 PM
04/13/12 04:52 PM
JohnRR Offline
JohnRR  Offline
You still never install the ebrock adapter bracket , it's never going to be right without it , the spot you have it is higher than stock and the ratio for the trans lever movement is wrong .
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: Hoop] #1214300
04/13/12 04:56 PM
04/13/12 04:56 PM
JohnRR Offline
JohnRR  Offline
Someone else posted to that thread and brought it to the top then the post was deleted , but that keeps it highlighted at the top...
When I opened it earlier I didn't look at the dates but it's been almost a year and you never installed the ebrock adapter ????
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: JohnRR] #1214301
04/13/12 07:46 PM
04/13/12 07:46 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
It may be the "wrong" way to do it, but when I installed my 4 barrel I just bent the original throttle and kickdown bracket until the throttle cable aligned right and bought a 2 dollar coupler nut and cut the head off of a bolt to extend the kickdown rod. Edelbrock sells the latter piece as some kind of an adapter for $15, mine looks exactly the same.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: Secret Chimp] #1214302
04/14/12 01:57 AM
04/14/12 01:57 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
This makes it sooo much easier
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: Hoop] #1214303
04/14/12 10:10 AM
04/14/12 10:10 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Either get the correct 4bbl kickdown or the cable kickdown from Bouchillion
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: BulletBob] #1214304
04/14/12 03:42 PM
04/14/12 03:42 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Hmmm
That looks like a G.M. throttle valve cable to me.
My 4 bbl. is a Holley but I just added a curved slotted bar from a /6 and it works great.
I have mechanical Aptitude.
I can screw up anything.
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: bboogieart] #1214305
04/14/12 04:19 PM
04/14/12 04:19 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
you guys need to quit showing him non-A body setups
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: Supercuda] #1214306
04/14/12 06:00 PM
04/14/12 06:00 PM
JohnRR Offline
JohnRR  Offline
nevermind incorrectly operating cobble jobs ...
