VIN number on pan rail decoding
#1214271
04/11/12 07:00 PM
04/11/12 07:00 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
A buddy came up with a C440HP block and Im wonderin what the VIN on the pan rail means. I guess that is a VIN number???
It reads TA162694, Casting date of 5-5-70.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: VIN number on pan rail decoding
[Re: Von]
#1214274
04/12/12 12:01 AM
04/12/12 12:01 AM
Posts: 17,529 Las Vegas, NV
6bblgt
Las Vegas, NV
![](/ubbthreads/images/graemlins/iagree.gif) sounds like the "top pad" reads G440 HP - What is the date stamped on there? ![](/ubbthreads/images/graemlins/scope.gif) the partial VIN# 1A162694 from a 440 4bbl or 440 3x2bbl Lynch Rd. assembled '71 Super Bee or Charger R/T block cast on 5/5/70
[Re: 6bblgt]
#1214275
04/12/12 12:19 AM
04/12/12 12:19 AM
Von
NE Oklahoma
Thanks for the info!! Is there anyway to determine if the block was a 6 pack block for sure? FWIW, it did have 6 pack rods in it.
[Re: Von]
#1214276
04/12/12 12:41 AM
04/12/12 12:41 AM
6bblgt
Las Vegas, NV
All '70 & '71 440HP engines have the "HEAVY RODS" regardless of number of carburetors. ONLY "IF" someone could find info on WS23U1A162694 or WS23V1A162694 or WM23U1A162694 or WM23V1A162694, "IF" 1A162694 is the stamped number. & it doesn't matter unless you know where that Charger is ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) the blocks are the same
[Re: Von]
#1214277
04/12/12 10:47 AM
04/12/12 10:47 AM
Posts: 75,134 A Banana Republic near you.
JohnRR
What else did it have in it ? Is it untouched from the factory or has it been rebuilt, if it's been rebuilt no real way to tell without a title that matches that partial VIN.
As said ALL 70 - 71 440's Hp and 6pk have the same rods, external balancer and oil pan.
