Re: Extrude honed exhaust manifolds, performance gain?
[Re: 426 Rocks]
#1213977
04/11/12 08:17 AM
04/11/12 08:17 AM
Posts: 20,065 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
I asked the same question a while back, and the general consensus was that the gains were minimal, and that the cost relative to the gains wasn't worth it.
Earning every penny of that moderator paycheck.
DBAP
[Re: 426 Rocks]
#1213978
04/11/12 09:31 AM
04/11/12 09:31 AM
Posts: 12,422 Taxes & Virus's R-US, NY
Dragula
Wondering if anyone has had factory exhaust manifolds extrude honed & how much flow capacity was gained & compared to a set of headers. Trying to figure out if that is the way to go on a 340 that will be stoked to 416 cu/in. Am trying to retain the stock look & want to get the most performance out of it that I can. thanks
Headers will be cheaper, and gain you more. If your trying to retain the stock manifolds because you don't want to change the exhaust, why even build a 416?
Lets put it to you another way. We built a 416 pump gas motor with stock heads mildly ported with a little larger valves...it choked it bad enough we couldn't get it below 11.50's in the 1/4 but it ran like a scoulded monkey in the 1/8th. It ran the top end of the 1/4 like a hurd of turtles.
Anywhere you hold it back on breathing is going to drastically limit it. Yes you will gain some cubes, and the torque along with it, but it will out breathe your stock intake, stock exhaust, your stock heads, and your carburator. Almost 75 more cubes is a big change.
If your going to go 416, give it a little to work with. If your going to spend cash on it, do it up right and give it somthing to work with.
Now we took a similar combo as the pump gas 416 and went and put W2 heads on it and we will see what that runs in a couple of weeks. Shooting for low 11's high 10's in a car that is heavier...You could paint the whole engine stock orange and put stock valve covers on it, and you would barely know. The nice thing about most W2 heads is the dual exhaust pattern. They will bolt up to just about anything.
[Re: DARTH V8Я]
#1213981
04/11/12 11:48 AM
04/11/12 11:48 AM
Dragula
...and don't let anyone tell you that you need headers to have good performance from your stroker;
100% correct
Define "good" performance. I go by ET..Loosing 50hp out of a small block is not what I would typically call "good" performance when it is there to be had.
Like I said, we have built them with nearly stock parts, and we have built them with with slightly better parts that can look stock, and there is a big gap between the two. 11:50-12.0 in a heavy street car is the norm with a 416 and stock parts. 10.50's are what we see out of well thought out combo that can still look deceivingly stock for a small block.
The runs good crowd loves the extra cubes and seemingly instant throttle response, and those of us with street/strip cars are not so happy because an unstroked 360 with good heads runs the same ET as our stroker with stock intake/heads and exhaust! We have guys running 9.90's with unstroked W2 engines and just a single 4 carb!
![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: DPelletier]
#1213983
04/11/12 12:00 PM
04/11/12 12:00 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
![](/ubbthreads/images/graemlins/iagree.gif)
...and don't let anyone tell you that you need headers to have good performance from your stroker; lots of FAST guys running them with manifolds and having incredible results.
![](/ubbthreads/images/graemlins/Twocents.gif) Dave
a FAST build and your basic 416 build are 2 different animals. I'd wager 100% of the fast guys would love to be able to run headers. Even a cheap small tube header is going to give you 15-20hp over a monifold. can you car run good with logs? sureit can but it will ALWAYS run better w/ headers. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Mr.Yuck]
#1213984
04/11/12 12:09 PM
04/11/12 12:09 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
This "discussion" has raged on here forever. Basically, it depends how you are looking at the question;
- Do headers typically provide a hp increase over stock exhaust manifolds? Yes.
- Can I build my engine to X horsepower using manifolds? Yes.
The LA stroker is a great combo that provides a welcome boost in torque over what's available in similar smaller displacement packages. Some people prefer the use of stock manifolds and are happy at the performance level that can be had using them.
Purestock and FAST have shown that you don't need headers to knock down some truly epic horsepower numbers.
....AND lastly, I've always said that you need to look at the ENTIRE exhaust system as a whole. I'd be willing to bet that my HP manifold, 2.5" mandrel bent TTI exhaust and dynomax ultraflows performs better on my car than a set of cheapie headers, stock compression bent 2.25" exhaust and crappy mufflers.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#1213985
04/11/12 12:47 PM
04/11/12 12:47 PM
Dragula
Well FAST and Pure Stock is a whole different level all its own and I really wouldn't compare those to this. Those guys look at everything for Hp...As I have said, we have built the small block strokers both ways, and it depends how you want to approach it.
I will say this. Build it with all stock parts, and then upgrade things later if you so desire. I would not spend the time or the money to extrude hone stock parts, when at half the cost, there are basic performance parts available that bolt right on.
[Re: DPelletier]
#1213986
04/11/12 12:54 PM
04/11/12 12:54 PM
dogdays
Extrude honing is the LAST resort method to increase performance. It is really costly, probably in the order of $50 per horsepower. I maintain DPelletier is half right. A free-flowing exhaust system is a much better use of your money. And that must include an H- or X- pipe.
What I maintain he is not right about is the true advantage of long tube headers where the exhaust pulses are separated from each other for the right amount of time. You can't do that with stock exhaust manifolds, HP or not. It's physics. In an exhaust system flow is not everything.
AndyF's dyno work found the MP .528 cam worked better than most other off-the-shelf cams in bigblocks.
And, FAST is appearance based. Except for the really low-buck racers, about every racer forced by the rules to use cast iron manifolds, either intake or exhaust, has them ported by professionals. Brzezinski comes to mind. It is naive to think those times are coming with totally stock equipment.
R.
[Re: dogdays]
#1213987
04/11/12 01:10 PM
04/11/12 01:10 PM
Posts: 75,126 A Banana Republic near you.
JohnRR
R.
correct , they aren't , the top guys have hand port exhaust manifolds and then they are extrude honed . what the extrude honing does is smooth the ruffness off the inside of the manifold which does help the flow. I have a set of A body specific big block manifolds that were hard ported then JET Hot coated inside and out. They weren't extrude honed , I wish they were but they would have cost me a lot more money.
Headers would be better but the one thing all the header flag wavers forget is the WANT of the person asking the question. What if they don't want headers ???
There is always going to be someone faster ...
Just about any engine with headers could be beat in a NON ELECTRONICS bracket race by a car running a 5 seconds slower with stock manifolds, it's all about CONSISTENCY ...
[Re: Dragula]
#1213988
04/11/12 01:13 PM
04/11/12 01:13 PM
DPelletier
FAST is a whole 'nother level; PS really isn't. I don't have much more in the way of $$$'s in my purestock build as I would in a stock, stock build. I agree with you on the extrude honing.
1974 'Cuda
[Re: dogdays]
#1213989
04/11/12 01:14 PM
04/11/12 01:14 PM
DPelletier
R.
good post and though I agree that flow isn't everything, it is usually the most important thing. I stand by my assertion that my car is faster as equipped than with headers and the stock exhaust.
1974 'Cuda
[Re: DPelletier]
#1213991
04/11/12 01:27 PM
04/11/12 01:27 PM
moparpollack
Lil Herman
Lil Herman
85086
A FAST racer posted that the money spent on extrudehone wasn't worth the cash. Worked better on paper than in the car.
[Re: 426 Rocks]
#1213992
04/11/12 02:00 PM
04/11/12 02:00 PM
Posts: 5,875 communist bloc of new jersey
jamesc
i've never had a set done but imho for the most performance/dollar value there would be a LOT of other places i'd be spending money before i did that. ![](/ubbthreads/images/graemlins/Twocents.gif)
