Re: carter avs rebuild kit?
[Re: v8punch]
#1213871
04/11/12 10:35 PM
04/11/12 10:35 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
What motor are you going to install that carb on
Also you can convert over to the flat metering rod covers from the edelbrock carbs , or just make your own flat ones to use on the AVS
That way you can run the edelbrock metering rods and jets for fine tuning
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: v8punch]
#1213872
04/12/12 12:02 AM
04/12/12 12:02 AM
Posts: 306 Texas
bogusracer
Texas
Go to this link for Walker Carb kits. they have everything you need for Carter, Holley and a multitude of other carbs out there. http://www.walkerproducts.com/index.php/products/carburetor-repair-kits/Prices are reasonable and you can then order them from O'Reilleys auto parts. Just call and give them the info ie. Walker Carb Kit 15304B. that is the kit for the AFB carbs for all years on the 426 Street Hemi. Price is around $34.00 for that kit. They also have an online store you can order various carb parts or bulk quantities of gaskets etc. if you race and rejet at the track and just need the gaskets and not an entire kit. Good luck Bogusracer
[Re: bogusracer]
#1213874
04/12/12 10:04 AM
04/12/12 10:04 AM
Posts: 302 MG, Brazil
v8punch
MG, Brazil
Thank's guys. It's a 4966s carb, originally used on 71 440. Mine has a 383 .030 over, 10.5:1 CR, 268 voodoo cam, headers, performer rpm intake, speed demon carburetor, unilite distribuitor... I'll go to oem apearence and will use carter, mp distribuitor and everyting else i can find. I'm not sure about change from headers to cast hp exaust manifold.
[Re: v8punch]
#1213875
04/12/12 11:02 AM
04/12/12 11:02 AM
bee1971
Sobieski Wi
You will not like that 4966s avs on that motor with all those mods as far as performance - Trust me you will notice a loss in performance , if that matters at all
4966s came on the 71 Non-HP 440 motors 625cfm carb
4967s/4968s came on the 71 HP 440 motors 750cfm carb
[Re: bee1971]
#1213876
04/12/12 04:02 PM
04/12/12 04:02 PM
v8punch
MG, Brazil
I know that but for now my goal is stock apearence. I live im a big city and unfortunaly with crazy traffic, drivers... my car is far away to be a garage queen but I do not drive it to much...
