If you have the skills and equipment, it can be done either way. If you are pressing the pin+bushing assembly into the LCA, you will need a tube-like device the same diameter as the outer shell of the bushing, with more reach than the pin.
Of course, pressing the bushing alone into the LCA first only requires that you support the inner sleeve of the bushing when it comes time to press the pin in.
It's all a matter of personal preference.
There might well be folks who step forward with their
![](/ubbthreads/images/graemlins/tsk.gif)
, but they are entitled to their own opinion.
