Water temperature sensor test #1212632
04/09/12 11:59 AM
04/09/12 11:59 AM
S.W. Pennsylvania
markrr Offline OP
markrr  Offline OP
S.W. Pennsylvania
How can I check the water temperature sensor and gauge on a '69 440 car? Can I just hold a lighter to the sensor and see the gauge rise?
Thanks.
Re: Water temperature sensor test [Re: markrr] #1212633
04/09/12 12:11 PM
04/09/12 12:11 PM
NJ
rth Offline
rth  Offline
NJ
remove wire from sending unit and ground it,with ign on gauge should sweep all the way.also check voltage at wire lead with ign on.
Re: Water temperature sensor test [Re: rth] #1212634
04/09/12 12:16 PM
04/09/12 12:16 PM
S.W. Pennsylvania
markrr Offline OP
markrr  Offline OP
S.W. Pennsylvania
Thank You.
Re: Water temperature sensor test [Re: markrr] #1212635
04/09/12 12:26 PM
04/09/12 12:26 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Ground the sender wire then turn on the ignition just long enough to see the needle move halfway. If you peg the needle you will burn out the gauge.
