Tuning 426 Hemi with O2 meter results (long)
#1212607
04/09/12 11:57 AM
04/09/12 11:57 AM
Posts: 1,029 Southeast Virginia
68jim
Southeast Virginia
Sorry if this gets a bit long…I would like to pass on the results of tuning the two Carter AFB carburetors on my 426 Hemi engine with the aid of an O2 meter. This is what I have, 68 Road Runner with 727 transmission and 4:10 dana rear. The engine is pretty much stock, factory intake, factory exhaust manifolds w/heat riser tubes and functioning choke, stock 68 mechanical cam. Factory dual point distributor with shorter slots and lighter springs. Repro exhaust from Accurate. Carbs were restored by Scott. First off, I can’t say enough good things about the great work Scott did on reconditioning my carbs. Knowing everything else was good on them made jet and rod changes easier without having to worry about something else on the carbs not being right. When I initially fired up the motor I had set my carbs up to run a bit richer than the factory jetting. I did the math and computed the area of the jet vs. area of the metering rod and set things up about 5-7% richer to compensate for today’s gas with ethanol blends. I got the motor running and even though it seemed to run well it still smelled a bit rich standing behind the car. I then had a few fuel related problems that I initially thought were caused by the carbs being lean – surging at cruise, etc. Turned out those were problems with the mechanical fuel pump and a loose clamp letting in air. So once those were fixed the carbs were even more rich. A buddy of mine has a LM1 O2 meter and offered to check my carbs if I would weld in the bungs needed for the sensor. I did that and then returned the jetting in my carbs back to 68 stock settings to establish a baseline. So Factory front carb setting was .089” primary, .080” secondary, .069”/.059 metering rods. Rear carb was .089” primaries, .092(left) secondary and .077” (right) secondary .069”/.054”left metering rod and .0715”/.058”right metering rod. Our local 93 octane premium (Exxon) has “up to 10% ethanol” so no idea really how much exactly is used. I also live 20 miles from the Ocean in Virginia so my altitude here is all of +20 feet. Driving out to my buddy’s place told me the factory settings were lean for cruise as the car had a noticeable surge, and the O2 readings confirmed this as well. It also told us that the Wide Open Throttle was rich. We made a few more changes to the metering rods, mostly in the rear carb, as we dialed in better numbers on the O2 sensor. I also noticed the car was responding as well with no more surge, cleaner looking exhaust tips and no more tears standing behind the car. This last weekend we made final metering rod changes and also to the secondary jetting to lean out the WOT numbers. I am going to call it good for now as I realize the jetting for carburetors, especially 2 of them, is all about compromise. I have cruise numbers in the 14.5 area and WOT runs in the 12.5 area with no pinging. Thanks to the guys in the other O2 tuning thread as I learned quite a bit from them. They are tuning at a level way above me but still a lot of good info there. So the final jetting numbers are not too drastically different but the O2 data backs up the changes. Hopefully it can be useful information for any other hemi guys running mostly factory configurations. Modified front carb setting now .089” primaries, .077” secondaries, .069”/.059” metering rods. Rear carb now .089” primaries, .089(left) secondary and .074” (right) secondary .065”/.052”left metering rod and .067”/.055”right metering rod. I’m sure I could get similar readings with different combos of jets and metering rods but my disclaimer would be that “It worked for me and your results may vary…”
Re: Tuning 426 Hemi with O2 meter results (long)
[Re: 68jim]
#1212614
04/09/12 06:20 PM
04/09/12 06:20 PM
Posts: 4,179 California
mickm
California
Thats interesting. I never had any hesitation issues, just the surge. Both of my accel pumps are set for the arm in middle hole.
mine is a whole different setup though. stage V manifold with 2 edelbrock carbs. so the theory is the same, but different components act differently!
[Re: mickm]
#1212617
04/09/12 11:56 PM
04/09/12 11:56 PM
Posts: 43,364 Bend,OR USA
Cab_Burge
i used my meter and got my numbers looking good, in the ranges people talk about here. but it had a hesitation when giving it throttle at most positions, so i went one step richer on cruise and power, (it was the only metering rod i had that went one richer on cruise, and was close to what i had at power).
the hesitation is mostly gone now. comes up once in a while.
short story is that each engine likes what it likes, even if it differs from the norm.
My meter may not be the same as others, that being considered I have leaned one of my carbs.out, on another pump gas iron headed motor , so lean that it started to ping. The Innovate LM1 meter showed that to be around 14.7 to 15.3. The current aluminum headed motor doesn't ping at the same AFR ratio Tune it to the way you like it Look at the spark plugs and go from there,no matter what the meter says ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Darryls-Demon]
#1212618
04/10/12 09:43 AM
04/10/12 09:43 AM
68jim
Southeast Virginia
What heat range plug are you using?
I've been using Champion RN12YC. I initially fouled out a set or two getting things working, but the last set has been there for 6 months or so. I can hear and feel it pretty quickly when they foul. Now that the carbs are dialed in better I will put in a new set and watch from there. The coil and plug wires are Jacobs items.
[Re: 68jim]
#1212619
08/16/13 10:16 PM
08/16/13 10:16 PM
Posts: 368 Jacksonville, Fl
426runner
Jacksonville, Fl
What is the theory/thinking behind the right and left differences in rear carb jets/rods?
Later, Sandy
'70 HEMI Road Runner B5/B5, 4 spd
"Sandy's Garage" on Facebook
[Re: 426runner]
#1801797
04/12/15 05:18 PM
04/12/15 05:18 PM
Posts: 1,138 Home of the Bluegrass
MoparJunkie
What is the theory/thinking behind the right and left differences in rear carb jets/rods? Anyone shed any light on this comment????
"It takes a Mopar to catch a Mopar” 1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54 2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
[Re: MoparJunkie]
#1801802
04/12/15 05:30 PM
04/12/15 05:30 PM
Cab_Burge
What is the theory/thinking behind the right and left differences in rear carb jets/rods? Anyone shed any light on this comment???? The factory OEM in line dual quad intake with the rear carb. being the part throttle running carb. dictates the overall jetting at WOT, the runner lengths on those intake are horrible once you take a hard look at them. I raced and tuned two different street Hemi cars(one stick and one automatic) in NHRA stock for several years, the jetting with open headers needs to be a little richer than stock for best MPH. Not much, maybe one Carter jet size depending on the D/A that day and track elevation, but a little. On the street with todays fuel a wide ban meter with recording capabilitys is your best tuning aid in my opinion. IHTHs
