Re: 727 Band Adjustment???
[Re: CUDAJAS]
#1212371
04/08/12 07:37 PM
04/08/12 07:37 PM
Posts: 26,038 Rio Linda, CA
John_Kunkel
Rio Linda, CA
For the front band you can use the "feeler gauge" method, use a piece of 5/16" or 3/8" rod between the servo plunger and the lever and tighten the band adjuster so the rod will pass through tightly. A roller from the overrunning clutch will work.
For the rear band use the 2 turns out adjustment.
