Electrical gremlins #1212241
04/08/12 08:12 AM
04/08/12 08:12 AM
Fredericton NB Canada
471b1dart Offline OP
Just put new engine in a 77 m880 truck , the old alt had a short in it put on new alt and battery , now have no power to anything , no lights , no power when you turn the key on , what should I look for??thanks
Re: Electrical gremlins [Re: 471b1dart] #1212242
04/08/12 10:35 AM
04/08/12 10:35 AM
starting at the batt positive post work your way to the bulkhead & check each connection till you find the open. If good to the bulkhead then work further on downstream inside the dash. EDIT the original short may have fried the fusible link there at the bulkhead
Re: Electrical gremlins [Re: RapidRobert] #1212243
04/08/12 10:55 AM
04/08/12 10:55 AM
places
79powerwagon Offline
places
If the other connects check out, this would be where I'd be starting, too.
Re: Electrical gremlins [Re: 79powerwagon] #1212244
04/08/12 08:59 PM
04/08/12 08:59 PM
Found the problem , traced wires back into dash and found the alt gauge had melted and burned the wires off , found a thread on another forum that explained how to rewire with out the alt gauge,
