Re: can't get 833 flush with bellhousing. Any suggestions?
[Re: frank]
#1211984
04/07/12 10:08 PM
04/07/12 10:08 PM
Posts: 1,357 central Florida
VL21
central Florida
Last one I did was by myself, I cut the hex off a couple long bolts, threaded them into the bell, this helped the alignment and took a lot of load off me!
It takes gasoline to interest me.
[Re: frank]
#1211986
04/08/12 03:15 PM
04/08/12 03:15 PM
Posts: 26,038 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Do as previously suggested, pry on the throwout fork to disengage the clutch a little than push the transmission in. If you used one of those plastic disc line-up tools they suck for alignment.
[Re: TooMany62s]
#1211989
04/08/12 06:03 PM
04/08/12 06:03 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
was this trans on this bell before? I agree with above. A 1/4 " is about the thickness of the bearing retainer and bolt heads preventing the teans from mating to the bell.
I am truckless..
[Re: 340SHORTY]
#1211990
04/08/12 07:40 PM
04/08/12 07:40 PM
John_Kunkel
Rio Linda, CA
The OP clearly states "The engine, tranny, and bellhousing are factory original."
