Mig welding and blowing holes #1211756
04/07/12 05:22 PM
04/07/12 05:22 PM
California
moparbroz Offline OP
California
I am burning holes through the original sheet metal on my '72 Satellite. Is the wire speed not fast enough? It's a Lincoln flux wire unit with a hi-Lo setting only.
Hebrews 11:1
Re: Mig welding and blowing holes [Re: moparbroz] #1211757
04/07/12 05:31 PM
04/07/12 05:31 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
what size wire are you using? need something around .020"
Re: Mig welding and blowing holes [Re: macmic87] #1211758
04/07/12 05:46 PM
04/07/12 05:46 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I'm a pretty amateur welder but if you can't control the heat you'll have to match the speed up till it's right on some practice scraps (bead sinks in just right, bacon cooking sound). If the wire speed gets to high it will want to make tall welds with poor penetration that require lots of grinding, or even not melt in fast enough and push you off the puddle. If the LO setting is just too high for the metal thickness you might be able to get away with just not hitting it for very long(tiny tack welds). As always proper gaps and especially clean fresh steel showing are super important. For body work you often want a million tack welds anyway- keep moving around to keep the heat from warping your panels.
Re: Mig welding and blowing holes [Re: radar] #1211759
04/07/12 08:11 PM
04/07/12 08:11 PM
California
California
Awsome! Thank you so much!
Hebrews 11:1
Re: Mig welding and blowing holes [Re: moparbroz] #1211760
04/07/12 09:34 PM
04/07/12 09:34 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
i think if you put a thin sheet of copper behind the metal it will block the wire and let it buildup and it wont stick to the copper and it is removed when done.i hope someone can verify this.
Re: Mig welding and blowing holes [Re: Clanton] #1211761
04/07/12 09:38 PM
04/07/12 09:38 PM
south jersey
W
welderboy Offline
welderboy  Offline
W
south jersey
Better off with solid wire and shielding gas! You'll be much happier!!
Re: Mig welding and blowing holes [Re: welderboy] #1211762
04/07/12 09:43 PM
04/07/12 09:43 PM
ky.
K
kenworth_goose Offline
K
ky.
The best weld would be with fluxcore wire and shielding gas. I was amazed at how good it works.
Re: Mig welding and blowing holes [Re: kenworth_goose] #1211763
04/07/12 09:47 PM
04/07/12 09:47 PM
south jersey
W
welderboy Offline
welderboy  Offline
W
south jersey
Never heard of that - don't get it, but may be worth a try...
Re: Mig welding and blowing holes [Re: kenworth_goose] #1211764
04/07/12 10:16 PM
04/07/12 10:16 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Yes I would be amazed, any second opinions on this method?
And on the copper backup trick, it should work, bronze would also be a solution, but IMO, its just a bandaid until you get yourself and welder dialed in.
Re: Mig welding and blowing holes [Re: moparbroz] #1211765
04/07/12 10:21 PM
04/07/12 10:21 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Save the flux wire for exhaust and brackets, it's too thick for the sheet metal. I admit, I have welded sheet metal that way, but it's alot more difficult, and the flux core wire creates alot of spatter. Get the gas kit, and the smaller mig wire and you will have much better results welding the sheet metal.
Re: Mig welding and blowing holes [Re: 451Mopar] #1211766
04/07/12 10:27 PM
04/07/12 10:27 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
I built a trailer frame with flux core. Great for thicker metals, but switched to 0.024" wire and gas for sheet metal. I was just blowing holes in sheetmetal with flux core.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Mig welding and blowing holes [Re: moparbroz] #1211767
04/08/12 12:07 PM
04/08/12 12:07 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Sometimes there is too much gap between the panels. If that's the case you might need to lay the gun down horizontally with the panel versus perpendicular. This will make it easier to bridge the gap.
Re: Mig welding and blowing holes [Re: Dave Watt] #1211768
04/08/12 01:25 PM
04/08/12 01:25 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
You can also use aluminum to back up the weld. I do this all the time and works just fine. Flux core is definitely not the first choice for sheet metal but it can be done.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: Mig welding and blowing holes [Re: herkamer] #1211769
04/08/12 02:17 PM
04/08/12 02:17 PM
IN
ahy Offline
ahy  Offline
IN
Usually with sheet meatal you "sticth weld". Work around the joint with short beads, 1/4" or less in length. Back and forth until it is completly welded. It helps prevent blow through and also heat distortion.
Re: Mig welding and blowing holes [Re: ahy] #1211770
04/08/12 06:14 PM
04/08/12 06:14 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
I agree that you would be better off with a gas conversion. In the mean time you should use heavier wire, seeing that you can't adjust the heat very well. The heavier wire will absorb some of the heat and help prevent burn through.
Re: Mig welding and blowing holes [Re: welderboy] #1211771
04/08/12 07:03 PM
04/08/12 07:03 PM
California
California
I know but not financially feasible right at the moment unfortunately.
Hebrews 11:1
Re: Mig welding and blowing holes [Re: Dave Watt] #1211772
04/08/12 07:08 PM
04/08/12 07:08 PM
California
California
Great idea! I will try that!
Hebrews 11:1
Re: Mig welding and blowing holes [Re: moparbroz] #1211773
04/09/12 01:15 AM
04/09/12 01:15 AM
MN
astrobuf Offline
astrobuf  Offline
MN
You really cannot weld sheet metal with Flux Core wirefeed. It's too uncontrollable. Seems like you must have a very odd Lincoln unit if it only has 2 speed settings. Even my old Lincoln WeldPak 100 has a pot to adjust feed speed.
To do this correctly, you will need to pop for a real MIG setup.
astrobuf
So, are you really a Rocket Scientist?
Re: Mig welding and blowing holes [Re: moparbroz] #1211774
04/09/12 09:09 AM
04/09/12 09:09 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I kicked myself for waiting so long before getting the gas shielding set-up on my welder.
immediately my welds went from splattery bird poop to nearly perfect looking beads. can't wait till I get back on my car and welding sheet metal with it.
going to gas is not expensive. you reverse the polarity on the welder from the flux core wire, and you can buy a regulator from Habor Freight for $20, then hit up your local TSC for a small bottle. I think it cost me about $200 to set up the gas shielding.
when restoring a car, $200 should NOT break the budget, or your car's restoration is really going to suffer!
remember it's a hobby. take your time, enjoy it, and do it right. if setting up the gas shielding means you wait a few extra months before buying the next replacement panel, then so be it. your results WILL be better
**Photobucket sucks**
