Re: F%$#@! TTI install, can't feed tail pipe
[Re: DARTH V8Я]
#1211718
04/07/12 07:44 PM
04/07/12 07:44 PM
Posts: 26 Blaine, MN
Buzzrider
Blaine, MN
You have it blocked up in the rear using the framerails(not the diff) so the rear wheels and axle are hanging, right? I have 2.5 exhaust (not TTI) and I got it in by doing this. I know I am stating the obvious, but I have done things before and had trouble and my cousin would point out the obvious to me that would make the job easier and all I can do is shake my head and wonder why I didn't realize that. Good luck.
[Re: DARTH V8Я]
#1211719
04/07/12 07:45 PM
04/07/12 07:45 PM
Posts: 755 Tempe, AZ
loco340cuda
Tempe, AZ
I installed a set of 3" TTI pipes on my Cuda about 4 years ago. I don't remember all the details but I do remember the tail pipes being a pain to get in. I did have to remove the rear valence to get them in. I did not have a rear sway bar so you might have to remove that as well (not sure). Maybe you can put the car up on jack stands and let the rear axel hang to give you more room (I can't remember if I did that or not, though I do remember I had the car up on 4 jack stands to give me more room under the car.) Hope this helps. Let us know how it turned out.
70 Cuda 340 4 speed - now stroked to 416ci (SOLD) 2017 Mustang Shelby GT350
[Re: Buzzrider]
#1211721
04/08/12 12:10 PM
04/08/12 12:10 PM
Posts: 4,762 Florida
BDW
Good luck.
I'll admit it, I'm an idiot, nothing is too obvious.
Once I disconnected the sway bar links and let the axle hang, I was able to slide the pipes in from the rear.
Thanks for the pic, this is going to be a PIA with the car only on jack stands.
Stay tuned for my next stupid question. At the rate I'm going this is going to be a week long project.
[Re: BDW]
#1211722
04/08/12 12:20 PM
04/08/12 12:20 PM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
I had to drop the valance to get my 3 inch system in.
ps: Your mailbox is full, so I am unable to get your information to ship your XV belts earlier this week.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: DANA60]
#1211723
04/08/12 01:39 PM
04/08/12 01:39 PM
BDW
I removed the shocks, and put them in from behind, but it was on a lift when I did it. That gave me the room from down to up.
Dana60, are your top shock mounts in the stock position, seem much more angled in than mine? Although just laying on the rear end at the moment, I have the pipes routed UNDER the shocks?
See, I already have another question, gonna be a long week.
[Re: BDW]
#1211724
04/08/12 01:51 PM
04/08/12 01:51 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Exhaust on my Challenger is inside the shocks...
[Re: BDW]
#1211725
04/08/12 09:16 PM
04/08/12 09:16 PM
Posts: 616 TP Exit 7, NJ, USA
DANA60
TP Exit 7, NJ, USA
The pic is from a B body I did, shocks are in a different local but the theme is the same. The E body ones go under the shock and sweep to the side of the gas tank. You'll need to get the car in the air, even with jack stands, but not under the rear, but under the frame so the diff. hangs, and remove the shocks.
