Re: Car is possessed! Need your hepl!
[Re: hemi_harvester]
#1211069
04/06/12 06:36 PM
04/06/12 06:36 PM
Posts: 2,048 N.E.Ohio
Polarabill
N.E.Ohio
It's always frustrating to be so close and then have problems.This is when I either step back and relax for awhile or call in reinforcements,meaning I call my brother or some one else just to come over and help me recheck everything. Sometimes the problem is so obvious that I can't see it and a fresh set of eyes can spot it right away. I'm sure you will figure it out quickly and be on the road soon.
This would be so much easier if I knew what I was doing...
[Re: bigblk66_coronet]
#1211073
04/06/12 07:35 PM
04/06/12 07:35 PM
RapidRobert
power flows thru the FL into the bulkhead then inside to the ammeter, thru it then to a splice where it T's to the light sw to the ign sw and to the fuse box. You just previously worked w the FL so I'd start there
#1211078
04/07/12 11:00 AM
04/07/12 11:00 AM
Posts: 5,912 Athens, Greece
Pyper70
Athens, Greece
Check your fusebox. My charger used to do that because I piggybacked all the wires off three 3 terminals for juice. I found out that the stress of the terminal cause a loose connection. The slightest jiggle would restore juice. I have since hooked up one cable and ran it to an 6-gang ATO fuse strip mounted close to the fusebox and divert power that way
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
#1211084
04/07/12 08:57 PM
04/07/12 08:57 PM
Posts: 843 Suffolk,VA
ireland383
Suffolk,VA
Ok i meant the starter relay not selenoid. And yep it you jump the posts its turns over.
Is your car an automatic? If so could be a bad neutral safety switch.
