8 1/4 rear axle #1210644
04/05/12 08:56 PM
04/05/12 08:56 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..what's the best way to tell an 8 1/4 from a 7 1/4?
..i should probably know this but can't remember.
Re: 8 1/4 rear axle [Re: can.al] #1210645
04/05/12 08:58 PM
04/05/12 08:58 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Didn't know they made and 8.25 TRANS ????
oops , he edited before I could hit the reply button ...
I think the 8 1/4 has 10 bolts on the cover , 7 1/4 has nine ... I bet you'd find the info in the TECH ARCHIVE in the time it took you to ask the question and my reply with an edit
Re: 8 1/4 rear axle [Re: JohnRR] #1210646
04/06/12 01:39 AM
04/06/12 01:39 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
Re: 8 1/4 rear axle [Re: nomore65BelvJim] #1210647
04/06/12 09:44 AM
04/06/12 09:44 AM
Franklin Co. Illinois
runinonmt Offline
runinonmt  Offline
7 1/4 uses 2 1/2" axle tubes,8 1/4" uses 3"
Ron
In sixty-five I was seventeen and running up one-o-one I don't know where I'm running now, I'm just running on Jackson Browne-Running On Empty
Re: 8 1/4 rear axle [Re: runinonmt] #1210648
04/06/12 10:29 AM
04/06/12 10:29 AM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
great info..tx!
Re: 8 1/4 rear axle [Re: can.al] #1210649
04/08/12 07:18 PM
04/08/12 07:18 PM
5thAve Offline
5thAve  Offline
Just remember if you are looking at an 80s one 7 1/4 also has 10 bolt cover and bigger axle tubes but they get narrower at the housing.
