Page 2 of 3 1 2 3
Re: $20 drive shaft loop no drilling required [Re: B_Body_Bob] #1209981
04/06/12 12:57 PM
04/06/12 12:57 PM
sweden
sshemi Offline
sshemi  Offline
sweden
I cant see how it is att at the crossmember but if it is well done there is no way in ... It gets ripped off.
Re: $20 drive shaft loop no drilling required [Re: sshemi] #1209982
04/06/12 01:05 PM
04/06/12 01:05 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Thinking along the lines of earthmover.
Weld the main loop together, removing the bolts sticking inside. Weld an extension on the outer sides and bolt that to your arms that attach to the crossmember.
Re: $20 drive shaft loop no drilling required [Re: RobX4406] #1209983
04/06/12 01:20 PM
04/06/12 01:20 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I do like the idea of getting the inside nuts protruding on the inside out of the equation.
I would agree the loop mentioned is better then nothing, just not by much.
I am puzzled by those who are so adverse to drill a couple of holes, but have little worry about how much damage a DS can do with a combined 12"? overhanging/swinging yoke and u-joint at say 100 mph just under your seat. The rotating twisted mess will rip those arms off in less then a second (6000 rpms, thats 100rpms/hits).
The design is IMO "very lacking" (edited) and may only serve the purpose of passing tech. Even the other guys hanging crossmember safety loop is as per designer NOT for competition use, and I give him
for admitting that.
Re: $20 drive shaft loop no drilling required [Re: jcc] #1209984
04/06/12 03:26 PM
04/06/12 03:26 PM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
Don't most u-joints are going to break at the initial hit, not at speed? I guess you could damage it and have it hold on for a while.
Re: $20 drive shaft loop no drilling required [Re: j.mcconnell] #1209985
04/06/12 05:10 PM
04/06/12 05:10 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
That would be the case if one assumes that the u joint is the weakest link, and i don't believe that's the case enough to discount all other possible driveshaft failures
Re: $20 drive shaft loop no drilling required [Re: jcc] #1209986
04/06/12 05:21 PM
04/06/12 05:21 PM
RobX4406 Offline
RobX4406  Offline
You could drill a hole in the top, through the floor and put a plate on your floor. Run a bolt through to secure it in a different plane.
Re: $20 drive shaft loop no drilling required [Re: jcc] #1209987
04/06/12 05:55 PM
04/06/12 05:55 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
a ujoint can let go anytime & anywhere. i have mine bolted to the floor boards with plates. don't think it's going anywhere. cheap is the wrong way to on safety or ur car.
Re: $20 drive shaft loop no drilling required [Re: 440Kilmartin] #1209988
04/06/12 07:42 PM
04/06/12 07:42 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
I had the car on my lift I grabbed the end of the loop and it was able to hold myself(200lbs) off the ground... Never budged... I'll get Another pic up
Well that is good enough for me. I withdraw my earlier statement. OR... maybe you should hit it 24 times with a sledge hammer to simulate a broken front driveshaft and see if it moved... Just yanking your chain, if it will hold up 200 lbs, I would think a driveshaft would be no problem.
Old Geezer Racing
Re: $20 drive shaft loop no drilling required [Re: SCATPACK 1] #1209989
04/07/12 07:42 AM
04/07/12 07:42 AM
sweden
sshemi Offline
sshemi  Offline
sweden
My english is not good enough to explain why the loop doesnt need to be super strong. If the shaft breaks and is kept close to centerline it wont do much damage, if that makes any sence
Re: $20 drive shaft loop no drilling required [Re: jcc] #1209990
04/07/12 08:32 AM
04/07/12 08:32 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Not all of them.
Many years ago I had a U-joint come apart just when I let off the throttle during a long overtaking action at the highway at a 'good rate of speed' (read: 100-110mph)...
The U-joint 'failure' could be traced back to my own stupid installation fault at the time, but luckily the driveshaft didn't entirely break loose from the transmission. The final result was a wrecked transmission with bend outputshaft and a carbottom covered in ATF.
Re: $20 drive shaft loop no drilling required [Re: BigBlockMopar] #1209991
04/07/12 09:55 AM
04/07/12 09:55 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
First off I've had 4 U joints break at speed . The 1st was on my 4 speed Challenger power shifting 3rd. It broke the bell housing off the block from vibration due to losing a cap. However the joint did not break and the shaft stayed in the car with no floor damage.The 2nd was at Budds Creak at the end of a 130 MPH pass. The front cap broke,not the joint. It broke the tail shaft. Shaft stayed in the car with no damage. The 3rd was driver error . He put my LBA valve body in 1st gear at 100+. It ripped the U-joint straps of the rear axle,so the shaft flung around pretty good.. The loop did its job,bent the mufflers some. I was able to get the shaft rebalanced at Dyno-tech. The 4th, a buddy driving his 66 Coronet down the X-way with no loop. The front joint broke. Ruined the shaft,came through the floor,broke the console,broke the tail shaft housing. But the best was the fact that most of the damage came from the output shaft of the 727 being bent at a 15 degree angle. As you can see from my experiences you never know the amount of damage. The damage could be to yourself. This is why I always plate the floor where the loop bolts.
Doug
Re: $20 drive shaft loop no drilling required [Re: sshemi] #1209992
04/07/12 10:23 AM
04/07/12 10:23 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Your communication skills are fine, but what many seem to overlook is not all DS failures are front u joint, they can be the rear joint, can be the front yoke, can be the DS itself, and can happen at any speed, since higher speeds cause greater runout, increasing chance of DS failure. If the failed DS was pristine and perfectly balanced, containing it inside a small perfect circle would be no big deal, but we are usually talking about a hugely unbalanced twisted 5'? long flexible tube, inside an oval, powered by a 3,000lb car accelerated by a 3-4:1 rear end, for hundreds of revolutions, and the mass is constantly increasing in diameter each revolution, extremely multiplying the forces. Hanging 200lbs on it as a test is like checking your timing with a wet finger.
Re: $20 drive shaft loop no drilling required [Re: jcc] #1209993
04/07/12 11:56 AM
04/07/12 11:56 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
The wet finger method has always done me right!
for setting timing of course
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: $20 drive shaft loop no drilling required [Re: OUTLAWD] #1209994
04/07/12 02:33 PM
04/07/12 02:33 PM
sweden
sshemi Offline
sshemi  Offline
sweden
The rule book doesnt say how secure it should be mounted right?
Re: $20 drive shaft loop no drilling required [Re: OUTLAWD] #1209995
04/07/12 10:08 PM
04/07/12 10:08 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
So you are the one on utube
Rule book also says nothing about min IQ.
Re: $20 drive shaft loop no drilling required [Re: 440Kilmartin] #1209996
04/16/12 01:11 PM
04/16/12 01:11 PM
CT
440Kilmartin Offline OP
CT
LOOP PASSED TECH YESTERDAY AND TECH GUY SAID "THATS PERFECT"
Re: $20 drive shaft loop no drilling required [Re: 440Kilmartin] #1209997
01/28/13 12:48 AM
01/28/13 12:48 AM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
So I made my own bolt on driveshaft loop for a winter project.
Started with a $25.00 Summit kit like the OP.
Used a piece of scrap from the metal dumpster at work.
It is 1/4" plate.
Grade 8 hardware was under $10.00.
Re: $20 drive shaft loop no drilling required [Re: pacifica] #1209998
01/28/13 12:50 AM
01/28/13 12:50 AM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
Re: $20 drive shaft loop no drilling required [Re: pacifica] #1209999
01/28/13 12:54 AM
01/28/13 12:54 AM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
Re: $20 drive shaft loop no drilling required [Re: pacifica] #1210000
01/28/13 12:58 AM
01/28/13 12:58 AM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
Bolt it onto the crossmember with existing through bolts. Drop back of driveshaft and slide hoop up to bracket and bolt together.
Page 2 of 3 1 2 3
