Page 1 of 3 1 2 3
$20 drive shaft loop no drilling required #1209961
04/05/12 12:36 AM
04/05/12 12:36 AM
CT
440Kilmartin Offline OP
CT
69 roadrunner 4speed.....20dollar jegs loop.. with some extra bends bolted it to the cross member similar to the high dollar ones out there.
Save your money!
Re: $20 drive shaft loop no drilling required [Re: 440Kilmartin] #1209962
04/05/12 12:46 AM
04/05/12 12:46 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Is it bolted or welded to the loop? I think I'll try something like this. I bought a cheap one but it will run into the X pipe if I tried to mount it like it should be, and the less drilling on the car, the better.
Re: $20 drive shaft loop no drilling required [Re: Exit1965] #1209963
04/05/12 12:52 AM
04/05/12 12:52 AM
CT
CT
all bolted in using 2 existing crossmember bolts
Re: $20 drive shaft loop no drilling required [Re: 440Kilmartin] #1209964
04/05/12 04:18 PM
04/05/12 04:18 PM
Sac, CA
mopowers Online confused
mopowers  Online Confused
Sac, CA
How bout another picture of the front of it? Looks real good.
Re: $20 drive shaft loop no drilling required [Re: mopowers] #1209965
04/05/12 07:09 PM
04/05/12 07:09 PM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
Yea more pictures would be great! I have the low buck summit loop and was trying to find a way to get it in without pulling my seats and carpet
Re: $20 drive shaft loop no drilling required [Re: j.mcconnell] #1209966
04/05/12 07:55 PM
04/05/12 07:55 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
looks like he ran 2 straight lenghts from cross member bolts to the hoop. good idea. i'd say the thickness of the straight peices should be heavier gauge then the hoop because of their length. i might make one myself.
Re: $20 drive shaft loop no drilling required [Re: rickraw] #1209967
04/05/12 08:25 PM
04/05/12 08:25 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
+1...or at least some gussets...granted more pics would make it clearer as to what was done, but the length of those straight members may compromise the integrity of the loop. I would much rather drill a few holes in the floorpan than deal with the carnage should the U joint let go...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: $20 drive shaft loop no drilling required [Re: OUTLAWD] #1209968
04/05/12 09:12 PM
04/05/12 09:12 PM
Az
Crizila Offline
Crizila  Offline
Az
Wonder if it will pass tech?
Fastest 300
Re: $20 drive shaft loop no drilling required [Re: OUTLAWD] #1209969
04/05/12 09:13 PM
04/05/12 09:13 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
I would be worried about that failing if the driveshaft let go.. The straight piece wouldn't fail, per se, but it would break or rip out at the bolt at the crossmember due to the moment.
Re: $20 drive shaft loop no drilling required [Re: Kevins493] #1209970
04/05/12 09:33 PM
04/05/12 09:33 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
I didn't think it would hold up either. I would like it better if it had a brace to one of the seat bracket bolts
Old Geezer Racing
Re: $20 drive shaft loop no drilling required [Re: SCATPACK 1] #1209971
04/05/12 10:35 PM
04/05/12 10:35 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
It looks like fairly thick steel, probably similar to what the $150+ that bolt to the crossmember are made of. I don't see it breaking up from a driveshaft rattling around in it for a few seconds.
I have the Allstar (generic) version in a box, if I can just bend the long pieces they intend to go across the width of the car, so that they go as they do in the OPs picture, it would seem fairly stout.
Re: $20 drive shaft loop no drilling required [Re: OUTLAWD] #1209972
04/05/12 10:58 PM
04/05/12 10:58 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
after studing his pic again, i think the drive shaft bangin around in the hoop would catch the bolts & rip everything out. one way to find out would to try it. hope that wouldn't happen to anyone.
Re: $20 drive shaft loop no drilling required [Re: rickraw] #1209973
04/05/12 11:46 PM
04/05/12 11:46 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
how about just weld it and pull the shaft if needed to remove..(where the bolts are at)
Re: $20 drive shaft loop no drilling required [Re: rickraw] #1209974
04/06/12 12:56 AM
04/06/12 12:56 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
The loop part is a standard design, there are lots of cars driving around with driveshaft loops like that.
If a driveshaft banging around would rip the steel off the crossmember, it would be more likely to rip out the thin metal of the floorboards which is where they are typically attached.
Re: $20 drive shaft loop no drilling required [Re: 440Kilmartin] #1209975
04/06/12 01:08 AM
04/06/12 01:08 AM
CT
CT
I had the car on my lift I grabbed the end of the loop and it was able to hold myself(200lbs) off the ground... Never budged... I'll get Another pic up
Re: $20 drive shaft loop no drilling required *DELETED* [Re: 440Kilmartin] #1209976
04/06/12 02:18 AM
04/06/12 02:18 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Post deleted by HPMike
Re: $20 drive shaft loop no drilling required [Re: HPMike] #1209977
04/06/12 09:59 AM
04/06/12 09:59 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
A driveshaft let go on one of the FAST RR's a while back. Broke the U joint at the front powershifting 1-2 on a 6"bias ply tire. Even with a properly installed, heavy duty loop(that did its job), it TORE UP the floors and crossmember and broke the transmission output shaft in two and shattered the tailhousing to pieces. You could probably hang 2500 pounds or more off a hardened 833 output shaft and not even bend it let alone break it...
MB
So all that damage happened because of (after) the driveshaft hitting the driveshaft loop? Sounds like the yoke got caught on the bolts inside the loop and torqued everything and broke it. For the driveshaft loop to rip the floor up, something more than a driveshaft rattling around inside it has to happen.
Re: $20 drive shaft loop no drilling required *DELETED* [Re: Exit1965] #1209978
04/06/12 10:08 AM
04/06/12 10:08 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Re: $20 drive shaft loop no drilling required [Re: HPMike] #1209979
04/06/12 11:37 AM
04/06/12 11:37 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
MB
You missed the point...
The loop didnt rip the floor up because it wasnt attached at the floor. The loop "contained" the shaft. Im sure it violently "danced" around inside the loop, but the shaft never fell. It bent up the the loop terribly, but it didnt break away. It was one of the US CARTOOL ones that bolts to the 4 bolts of the crossmember.
MB
I didn't think your story made any connection between the carnage of the RR you describe, and whether the OPs driveshaft loop will work. Maybe that wasn't your point, even though you said "Even with a properly installed, heavy duty loop" it tore up the floor and crossmember, which certainly sounds like you were suggesting that the strength/design of the driveshaft loop played a large role in the damage to the RR. If not, what was the point, and what does the properly installed, heavy duty driveshaft loop have to do with a torn up RR?
Maybe your main point was that hanging weight off something is not a good test, if so it was only made at the end of your example. Fair enough, but it hardly addresses whether OPs driveshaft loop would work as intended if a driveshaft fell into it.
Re: $20 drive shaft loop no drilling required [Re: HPMike] #1209980
04/06/12 11:50 AM
04/06/12 11:50 AM
Almost Heaven
B_Body_Bob Offline
Master of nothing
B_Body_Bob  Offline
Master of nothing
Almost Heaven
To me that confirms the modified loop would work fine to contain the shaft. From looking at the photo, it seems the OP's loop may be stouter than the US Car tool part is. The modification in this thread hangs the loop by the sides on two pieces of steel, the US Car Tool part hangs the loop by one piece of steel at the bottom.
Everybody makes fun of a hillbilly until they need something fixed
Page 1 of 3 1 2 3
