Re: AAR / TA 2 way mufflers HP loss?
[Re: Moparmal]
#1209761
04/10/12 05:50 AM
04/10/12 05:50 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
I resurrected this thread because I found some interesting info on the original AAR /TA muffler design ...and got onto a performance replacement,. Not for the resto crowd, but any FAST racers running either of these Mopars may be interested....... Firstly, a reply to an email I sent: WOW Mal - I wrote that a long time ago - I'm surprised you recalled this. The systems on the AAR's & T/A's were dual 2.25" - I own an AAR, though it is not ready for the road yet - still under a tedious restoration.
The OE mufflers (reverse flows) are just a poor internal design so they flow like crap. We flow tested one of them when I worked for Dynomax, that's where I got the 156 CFM flow #'s from. Compared to a Dynomax # 17675, which has a flow rate of 517 sCFM. I would not hesitate to run this Super Turbo on your car, as it has a VERY good flow rate. The 2.5" version of this same reverse-flow muffler is part # 17676 (the 17675 is a 2.25" in/out) & the 2.5" version has a flow rate of 539 sCFM. These are a standard oval size (4.25" thick x 9.75" wide), x 14" long bodies, so they are shorter than the OE AAR/T/A mufflers by 6". Eric Sauls President – CCEI Classic Chambered Exhaust, Inc. P.O. Box 424 Milford, MI. 48381 Phone: (248) 889-4364 Second - here's a deal. http://www.summitracing.com/parts/WLK-17676/Hope someone finds this useful info -
[Re: scatpacktom]
#1209763
04/10/12 11:40 PM
04/10/12 11:40 PM
Posts: 419 NY
F1Scamp
NY
Me too. They rot out real quick though.
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
[Re: F1Scamp]
#1209764
04/11/12 12:01 AM
04/11/12 12:01 AM
Posts: 6,018 Salem
Grizzly
Moparts Proctologist
Salem
A member mentioned on here a few years ago in a thread about T/A exhaust, that there is also a muffler used on the Mustang Cobras that were in/out on the same side. Don't recall any flow numbers. Does this ring any bells? Often thought of asking whoever makes the T/A exhaust system to make 3" available and without the deflectors in the tips...........
Mo' Farts
Moderated by "tbagger".
[Re: scatpacktom]
#1209766
04/11/12 10:11 AM
04/11/12 10:11 AM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
I think they rust quickly because the gas we use and we start em up and shut em off.
Yep.....
MB
[Re: HPMike]
#1209767
04/11/12 12:10 PM
04/11/12 12:10 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Yep.....
MB
2 aspects caused them to rust out easy... the gases plow into the wall and if you run short times it never dries up the moisture... once the aluminized coating burns off it rusts easy
