used oil testing?? Anyone doing it? #1209710
04/04/12 06:09 PM
04/04/12 06:09 PM
Connecticut
5126brl No more Offline OP
Connecticut
How many on here test their used oil to see how it is holding up and if issues are showing?
What lab are you using and cost.
Results?
Re: used oil testing?? Anyone doing it? [Re: 5126brl No more] #1209711
04/04/12 08:09 PM
04/04/12 08:09 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I used Blackstone.I don't remember the cost.I had my 2002 Ram quad cab oil checked a few times as I wanted to see how it was doing with the 15w40 diesel oil I use.The results were detailed and I would use them again.
Nautilus Racing-
Re: used oil testing?? Anyone doing it? [Re: Chris2581] #1209712
04/05/12 01:16 PM
04/05/12 01:16 PM
dogdays Offline
dogdays  Offline
I've used Titan Labs in Denver, CO. You buy the kit which includes a prepaid envelope and sample bottle. At the time it cost less than $20 per kit. It's worth it to see what's going on in the engine.
R.
Re: used oil testing?? Anyone doing it? [Re: dogdays] #1209713
04/05/12 01:23 PM
04/05/12 01:23 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
napa sells the kit about $15 includes testing
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: used oil testing?? Anyone doing it? [Re: 440lebaron] #1209714
04/05/12 05:41 PM
04/05/12 05:41 PM
A57_RT Offline
Parts Problem
A57_RT  Offline
Parts Problem
I use the local cat dealership, when they service the big equipment they send samples out on a reg bassis to see what parts are wearing, they can also do my trans fluid as well as rear diff fluid at a fair price.
Re: used oil testing?? Anyone doing it? [Re: 5126brl No more] #1209715
04/05/12 06:53 PM
04/05/12 06:53 PM
Az
Crizila Offline
Crizila  Offline
Az
Used to do it regularly for certain pieces of equipment ( expensive stuff or stuff that ran in a bad environment - street sweepers, fire trucks, etc. ) in the fleet I was maintaining. It was good for setting maintainence intervals and spotting potential problem areas early - but, it was pretty useless without having a history to look at ( trend analysis ). Of course, you could always spot a catastrophec failure, but you usually didn't need an oil analysis for that . To get full benefit from oil analysis, you need to start by supplying a virgin oil sample as a base line ( TBN ). Then keep on a very ridged sample interval and don't change anything. A lot can screw up the readings ( oil usage between intervals, any engine repairs, sealing materials used, gasket materials used, intake filter leaks / clogs, etc., oil additives, even adding oil between samples of a different brand ) and if you are the least bit paranoid, your gonna be doing a lot of unnecessary tear down work due to miss-reading the sample. A high silicon reading can mean several different things - one as simple as a leaking air filter or blowing dust. I won't even get in to fuel dilution. Also keep in mind that when there is a part failure in our type of invironment, there is seldom an early marker, at least not between "normal" maintenance intervals. In short, oil analysis has it's place, but it aint here. JMHO.
Fastest 300
