Kinda hard to understand what you're saying but I'll give you my scenario.
68 super bee- heat controls are dead center on the dash underneath the dash cap.
I had one of the levers when I moved it bend like yours sounds like. Eventually it broke...imagine taking a coat hanger wire and bending it back and forth. eventually it will get so weak that it breaks. What I'm getting at is you might just need the whole part.
https://www.yearone.com/Catalog/Show?bid=24&sid=132&ssid=663&pgid=0 Just showing yearone as a reference. Under "interior" look up vent cable or heater control cable.
hope it helps
