REMOVING PAINT SCRAPE #1209647
04/04/12 12:51 PM
04/04/12 12:51 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Co-worker has a red spot on her green Honda from where I'd say a car bumper rubbed up against it, doesn't appear to be dented.
What would be good to remove this w/o dulling the clear?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: REMOVING PAINT SCRAPE [Re: Magnumguy] #1209648
04/04/12 01:01 PM
04/04/12 01:01 PM
PA
noplanb Offline
noplanb  Offline
PA
Clay bar.
remember when you said honey, some day that car is gonna look so good in front of our house
Re: REMOVING PAINT SCRAPE [Re: noplanb] #1209649
04/04/12 01:43 PM
04/04/12 01:43 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: REMOVING PAINT SCRAPE [Re: Magnumguy] #1209650
04/04/12 05:07 PM
04/04/12 05:07 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I'd do the clay bar as mentioned, but surprisingly most times WD-40 will work if the scuff is fresh, WD-40 won't hurt the paint in any way, other than remove the scuffed on paint from the other vehicle, WD-40 is also good for removing overspray paint, if you catch it while it's "fresh"
