Will a B-body 66-70 K-frame work in a 62-65 B-body?
#1209616
04/04/12 10:40 AM
04/04/12 10:40 AM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
Want to know if a 66-70 B-body K-frame will work right in a 62-65 B-body. Thanks!
RS23L7 4-Speed
Re: Will a B-body 66-70 K-frame work in a 62-65 B-body?
[Re: JohnRR]
#1209618
04/04/12 11:09 AM
04/04/12 11:09 AM
Mopar_Mike
Danville, NH
Thanks John, Sounds like more work that its worth!
RS23L7 4-Speed
[Re: JohnRR]
#1209620
04/04/12 11:17 AM
04/04/12 11:17 AM
Mopar_Mike
Danville, NH
No, I want to sell a K-frame I have and someone wants to use it in a early B..
Hey, did Miller go out of business?
RS23L7 4-Speed
[Re: JohnRR]
#1209622
04/04/12 11:20 AM
04/04/12 11:20 AM
Mopar_Mike
Danville, NH
Ouch... Is there anyone else around? I need a cam installed in my Hemi
RS23L7 4-Speed
[Re: JohnRR]
#1209624
04/04/12 11:24 AM
04/04/12 11:24 AM
Mopar_Mike
Danville, NH
yeah, I never did one before and don't want to "experiment" on this build.
RS23L7 4-Speed
[Re: Mopar_Mike]
#1209626
04/04/12 03:38 PM
04/04/12 03:38 PM
Posts: 26,039 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I've done several late K-member conversions in early B's, the motor is setback 1 5/8" which makes for more fan clearance and allows the use of later pans and headers.
Since the steering remains the same the idler arm only needs to be correct for the mounting style. (single stud or through bolt)
[Re: John_Kunkel]
#1209627
04/04/12 04:17 PM
04/04/12 04:17 PM
Posts: 1,443 Maryland
Dads426
Maryland
![](/ubbthreads/images/graemlins/iagree.gif)
The trans crossmember can be modified so the "box" is set back into the trans crossmember and you can use the cheaper 66-70 B-Body trans mount. Single 4bbl will fit, but the crossram will require some firewall massaging... ![](/ubbthreads/images/graemlins/hammer.gif)
[Re: Dads426]
#1209628
04/04/12 08:44 PM
04/04/12 08:44 PM
Dads426
Maryland
Pic of the modified crossmember:
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: 383man]
#1209631
04/05/12 10:44 AM
04/05/12 10:44 AM
Posts: 671 Los Osos, Ca
CKessel
Los Osos, Ca
I have one of each of those frames and it looks like more than 1 5/8" difference. I will have to actually measure this weekend. Did anyone have any interference issues at the firewall with a b-motor, especially around the hvac plumbing?
Carl Kessel
[Re: CKessel]
#1209632
04/05/12 01:28 PM
04/05/12 01:28 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I have an A/C car without the A/C components. There are no problems than I can see. It might be different if it actually had A/C.
