big block bellhousing for overdrive tranny?
#1208912
04/03/12 01:39 AM
04/03/12 01:39 AM
Posts: 8,859 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
Just curious if they ever used the 833over drive behind any type of big block as i have a few of them and a stock 440
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: big block bellhousing for overdrive tranny?
[Re: DaytonaTurbo]
#1208914
04/03/12 02:05 AM
04/03/12 02:05 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
actually there is a factory big block bell that had the dual bolt pattern and the 5.125 hole. The NP 435 uses the 5.125 hole also. They are extreemly rare and cost big money if you are lucky to find one.. .
I am truckless..
[Re: Strongbad]
#1208918
06/10/12 08:08 PM
06/10/12 08:08 PM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
The A 833 and the OD 833 use different front bearing retainers. The 8ss uses a 4.80 diameter retainer and the OD 833 uses a 5.125 diameter retainer.
Id wager the 670 bell uses a 11" flywheel/clutch. My reasoning is the only 4 speed behind a BB in a truck would of been a NP435/445. The research I have done shows that the 670 bell was only available in 77/78.. .
I am truckless..
[Re: 77ProStreet]
#1208920
06/10/12 08:35 PM
06/10/12 08:35 PM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Thats a great price. The only 1 I has seen had a $350.00 dollar sticker on it. Its nowhere near as common as the SB dual pattern bell.
I am truckless..
[Re: PC-CHARGER]
#1208924
10/28/14 06:26 PM
10/28/14 06:26 PM
Posts: 4,285 Ohio
64dodge572
Ohio
Overdrive input gear is the smallest of the 23 splines with only 22T. Some iron A/F overdrive trans used the normal 307 front bearing.
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: toplescuda]
#1208925
10/28/14 06:45 PM
10/28/14 06:45 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
You guys do realize I asked this ? April of 2012?lol
