tack ? #1208902
04/03/12 12:42 AM
04/03/12 12:42 AM
littlestown pa
dustpan man Offline OP
littlestown pa
I got an autometer monster5in and it reads 1000rpm less then the motor i got a orange box u think i might need a tack adapter?
Re: tack ? [Re: dustpan man] #1208903
04/03/12 01:16 AM
04/03/12 01:16 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Not with an orange box, no. Tach adapters are for stuff like multi-spark ignition boxes. With the orange ecu you should just have the tach going to coil -. If it's reading wrong time for a new tach. You're sure you got the tach on the 8cyl setting?
Re: tack ? [Re: DaytonaTurbo] #1208904
04/03/12 01:52 AM
04/03/12 01:52 AM
littlestown pa
littlestown pa
It is on 8 I've re ground it and re wired it still the same thing every Time i check it with my snapon timing light
Re: tack ? [Re: dustpan man] #1208905
04/03/12 11:09 AM
04/03/12 11:09 AM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
FWIW, it's tach, short for tachometer. I had to click on the thread to see if you were sailing or not.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: tack ? [Re: DPelletier] #1208906
04/03/12 01:19 PM
04/03/12 01:19 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
his tack is off track.
I am truckless..
