A-body drum/disk brake conversion question #1208816
04/02/12 11:39 PM
04/02/12 11:39 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
I'd like to buy a set of 68-72 small bolt pattern disk brakes to convert my 69 Dart from manual front drum brakes to manual disk. What I would like to know is if I get a set of factory SBP disk brakes, do I have to change the upper and lower control arms or were the same arms used for both drum and disk?
Re: A-body drum/disk brake conversion question [Re: 1970RT] #1208817
04/02/12 11:41 PM
04/02/12 11:41 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Same control arms, different spindle and lower ball joint.
Re: A-body drum/disk brake conversion question [Re: nomore65BelvJim] #1208818
04/03/12 01:47 AM
04/03/12 01:47 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Do you have 9" or 10" brakes? You can get new brake kits that bolt on to the stock spindles and will accept either sbp or lbp wheels. I have wilwood with dual bolt parents. Just a thought.
