Prestolite dual point dist #1208812
04/02/12 11:36 PM
04/02/12 11:36 PM
Wendy, I'm home.
dstryr Offline OP
dstryr  Offline OP
Wendy, I'm home.
Ya know that little spring steel wire keeper that secures the vacuum advance arm to the post on the breaker plate?
Where can I get one of those little (&*#_)?
dstryr, since 1986.
Re: Prestolite dual point dist [Re: dstryr] #1208813
04/02/12 11:42 PM
04/02/12 11:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I think an E clip would work , that's what i plan to use .
Re: Prestolite dual point dist [Re: JohnRR] #1208814
04/02/12 11:54 PM
04/02/12 11:54 PM
Wendy, I'm home.
dstryr Offline OP
dstryr  Offline OP
Wendy, I'm home.
Thanks,
I was taking mine apart tonight and thought I had the clip under my finger as I pried it off. I didn't see it fly or hear it land.
Hate losing original parts...
dstryr, since 1986.
Re: Prestolite dual point dist [Re: dstryr] #1208815
04/03/12 11:57 AM
04/03/12 11:57 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks,
Get a magnet and run it thru you dirt pile after sweeping up or vacuuming the area , bench top included . I know what you mean by losing an original part , when I took my first one apart that clip wasn't easy to get off and I'm pretty sure I just used an eclip
