Need to know what gauge metal to use to repair a few small sections of subframe. As I put my new pans in, I'm fixing things I did wrong many years ago. I had gotten into the subframe in a few areas on the flats with the arc welder and "fixed" them.....which of course meant more arc welding. My skills back then were rudimentary to say the least. I found some lumps and bumps underneath. I'd rather not get into the ugliness of the repairs. Suffice it so say I plan to fix it right.
I could grind and weld but some slag may remain and I'd rather have my frame solid metal. Maybe its just me but I prefer it that way.
Safest best is to cut those areas out and replace them.
Question is....what gauge metal should I use? Looks like 14 gauge maybe? Also does it need to be hardened or heat treaded or something? Or is it just mild steel? I need to fix this right before proceeding.
Areas I want to cut and replace are circled.
(PS...pretty photo huh? The only way to get my "homemade pans" out was to cut around my original welds. I'm going to hit the boneyard and look for an entire tunnel. If I can't find one....it's fabrication time)
