Re: 1968 satellite wagon
[Re: Deans68plym]
#1208610
04/03/12 02:08 AM
04/03/12 02:08 AM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
The choke is probably set too lean and the fast idle might be set a little low. Until I fixed the choke on my car it WOULD NOT START unless you stomped about a quarter bowl's worth of accelerator pump shot down the carb.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: 79powerwagon]
#1208612
04/03/12 11:24 AM
04/03/12 11:24 AM
Posts: 416 Franklin Co. Illinois
runinonmt
While you are checking the choke give it a good spray with carb cleaner,make sure all of the linkages are free. Also check the manifold heat control(the floppy thing on the right manifold if it has one)if it's not free it will give poor drivability in cold weather(stuck open) or carb boiling(stuck closed). Ron
In sixty-five I was seventeen and running up one-o-one
I don't know where I'm running now, I'm just running on
Jackson Browne-Running On Empty
[Re: mro]
#1208613
04/03/12 11:45 AM
04/03/12 11:45 AM
Posts: 1,357 central Florida
VL21
central Florida
It is common on these for the heat crossover to carbon up so badly it plugs, which results in the choke not opening after warm up. It is possible that has happened and a PO has either adjusted/disconnected the choke. I couldn't count the ones I have run across with this problem. Decarboned,and choke set up properly, works pretty well. Hand choke is another solution, done that too.
It takes gasoline to interest me.
