Re: Big block A-body question
[Re: 1970RT]
#1208589
04/02/12 09:44 PM
04/02/12 09:44 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I used the small block center link.My car was a 340 car and I didn't change anything in the front end except for brakes.
[Re: Chris2581]
#1208590
04/02/12 10:04 PM
04/02/12 10:04 PM
Posts: 20,228 Park Forest, IL
slantzilla
Park Forest, IL
The later A bodies only have one style centerlink for each generation.
[Re: Danan]
#1208593
04/03/12 02:13 AM
04/03/12 02:13 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
The center link will work fine.. You need to use a C body pan with the notch for idler are clearance..
I am truckless..
[Re: slantzilla]
#1208596
04/03/12 11:54 AM
04/03/12 11:54 AM
Posts: 75,126 A Banana Republic near you.
JohnRR
I've heard that the later style center link provides more oil pan clearance than the early style. Not sure if this is true, but will be finding out in the somewhat near future..
The late '73-76 centerlink will require the late Pitman and idler arms too. It mounts differently than the '67-72 ones do.
and the late pitman arm requires a 73 or newer steering box wit hthe large output sector shaft , you can't just changeover to the newer centerlink .
