Hey Guy's, What is the best way to install a drivers door window on a 69 Superbee hardtop with flip out back windows. Does it need to be installed with the vent window and door window as an assembly or can it be installed seperatly. As in vent window assy. installed first then put the window in after the vent window assy. is in? Thanks!
