Re: Distributor Corrosion
[Re: FASTBACK340]
#1208300
04/02/12 05:01 PM
04/02/12 05:01 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
You may also want to check your rotor phasing. When mine was off, it caused a massive acceleration of the corrosion process. I guess because of the ionization going on when the spark had to jump so far to reach the terminal. Mine was really off.
I used a small wire bush to knock down the corrosion and coated the metal surfaces with a spray on WD-40 type spray.
Once I corrected the rotor phasing, the corrosion process slowed down to 10% or less than what it had been doing.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: FASTBACK340]
#1208301
04/02/12 06:06 PM
04/02/12 06:06 PM
Posts: 952 Queens, N. Y.
FASTBACK340
Queens, N. Y.
I held my breath when I posted this for fear of the obvious.... but MSD's have a habit of corroding? Are the parts that low grade? It sure wasn't an inexpensive piece..... but I own it.
I'll clean it up and lightly coat w/ WD-40. I still need info on the phasing. Google here I come...
Thanks for the advice!
`68 Barracuda 340-S
[Re: FASTBACK340]
#1208303
04/02/12 06:35 PM
04/02/12 06:35 PM
jbc426
West Coast, USA
Mine was so far off, it almost took the full amount of adjustment available on their adjustable rotor. I'm surprised it wasn't firing on the next cylinder.
[Re: FASTBACK340]
#1208304
04/02/12 07:41 PM
04/02/12 07:41 PM
FASTBACK340
Queens, N. Y.
I did a Google on the subject and learned quite a bit about MSD's.
I was reading a thread on another forum where guys would have identical cars (Factory Five Cobras) and one would have corroding components and the other would be perfect. Same cars, same components, same state, same town, same climate, same storage situations. A nd no solutions...
You should read some of the theories!
`68 Barracuda 340-S
[Re: FASTBACK340]
#1208305
04/02/12 07:54 PM
04/02/12 07:54 PM
RapidRobert
K.i.s.s. I'd say very high humidity over a period of time and bare unprotected ferrous metal and condensation with falling/changing temps below to the dew point. Had it happen to me several times not related to MSD tho
