No rear brakes
#1207895
04/01/12 10:34 PM
04/01/12 10:34 PM
Posts: 219 Ontario Canada
300_dup5
Ontario Canada
Hello, new lines , new prop and meter valve, drum to dis conversion,,, we put fluid in new system for first time. We got good front brakes, but no rear. Had fluid to prop valve, but nothing to exit port for rear. We took it off and found that we could not even blow air threw with my small brake bleeder. Could the prop unit be defective,, anybody run into this before. Thanks in advance
Re: No rear brakes
[Re: 300_dup5]
#1207897
04/02/12 01:00 AM
04/02/12 01:00 AM
Posts: 43,317 Bend,OR USA
Cab_Burge
Its toast or defective, replace it
Re: No rear brakes
[Re: 300_dup5]
#1207898
04/02/12 07:58 AM
04/02/12 07:58 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Might be the pin is off in the PP valve.Ive had a buch that did the same thing at work.Try tapping on the valve.Ive also had a few reset by opening the frt bleeder and pushing the pedal real hard.Sometimes it takes a few stabs to reset them.Rocky
Chrysler Firepower
