4 speed install and clutch linkage instal #1207198
03/31/12 09:19 PM
03/31/12 09:19 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
A couple of questions. I am new to 4 speed install. Car 1s 69 GTX. Putting 833 trans back in. There is no clutch linkage installed yet. Engine is in the car. Pressure plate and clutch disc bolted to flywheel. Engine, bellhousing, and tranny are original. Clutch and pressure plate is McCloud performance parts. What is next? I would like to install tranny but is there linkage that needs to go on first?? What is the best order to reinstall all necessary parts. Any tips you could provide? Thanks
Re: 4 speed install and clutch linkage instal [Re: frank] #1207199
04/01/12 01:28 AM
04/01/12 01:28 AM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
There should be a throwout bearing and lever in there. I suggest a service manual.
