Re: Emergency help needed question on airgrabber setup!!
[Re: dangina]
#1206765
03/31/12 02:00 AM
03/31/12 02:00 AM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
i assume it is suppose to sit flush then
Yes. Hard to tell from pics, but if hood fits correctly on car, hood is probably correctly curved. Bubble needs to sit flush, or as flush as possible.
My hood and bubble are fiberglass also. Bubble fits flush in center rear and has a gap of about 1/8" at the rear corners - not a perfect fit, but since the bubble is black, it's not too noticeable.
Since the bubble is fiberglass, I used long set screws threaded into the "pads" molded into the underside of the bubble, so I wouldn't have to screw and unscrew bolts/screws into the bubble if/when I put it on/remove it. THe set screws, IIRC, are 1/4" diameter, perhaps 1" or 1-1/4" long or so, screwed into the pads on the bubble with a little bit of glue or epoxy, so they're not coming out or pulling out (hopefully).
I got the set screws from TacomaScrew (since they weren't far from where I lived at the time), but you may be able to find them at a decent auto parts place.
http://www.tacomascrew.com/products/search/set%20screw
Good luck with it.
[Re: MoparMarq]
#1206766
03/31/12 02:24 AM
03/31/12 02:24 AM
Posts: 1,491 Lethbridge, AB, Canada
dangina
Good luck with it.
curious - where did you buy your hood and airgrabber from?
[Re: dangina]
#1206769
03/31/12 03:15 PM
03/31/12 03:15 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
A few years back someone posted a substitute for the cupped washer/nut, I should have saved it, the cupped washer was very close, not exact but close enough that most folks wouldn't notice & instead of $15 per nut/washer it was $15 for enough to do the whole hood... Anyone else recall the source?
[Re: moparbroz]
#1206772
03/31/12 03:58 PM
03/31/12 03:58 PM
Posts: 339 California
moparbroz
California
The article calls the substitute material a "sweat plumbing nipple." It is actually a basic 1/2 copper coupling. Quote:
https://board.moparts.org/ubbthreads/upload2/6527502-Fromscooptonuts4.pdf
Hebrews 11:1
[Re: dangina]
#1206775
03/31/12 04:39 PM
03/31/12 04:39 PM
MoparMarq
Vancouver, WA
Some guy in Minnesota. I don't think he's doing it anymore. When I bought the hood, it took him 9 months to get it to me. ![](/ubbthreads/images/graemlins/eyes.gif)
That was probably 8 years ago...
[Re: dangina]
#1206777
04/03/12 11:48 PM
04/03/12 11:48 PM
dangina
does anyone have any pics or a step by step guide on how to setup the flapper and air grabber door on the airgrabber?
