Re: installed the holley 850hp street carb........but???
[Re: Mr.Yuck]
#1206286
04/04/12 04:14 PM
04/04/12 04:14 PM
Posts: 1,039 ALBERTA CANADA
CUDA8U
ALBERTA CANADA
ok,from the beggining...i managed to get the car running but now have a dead spot when i stomp on peddle in park and hesitation when kicking in 4 barrels.
I measured 2.25"s from timing mark to get my 36 over all timing,intial is about 17 now,set fuel level in bowls to slow trickle,adjusted the 4 corner idle mix for best vac with guage,changed front and back squirters from 29 to 32's,new plugs,new rotor/cap......still hesitating
the 850 holley street hp comes with 80jets 45 power valve,80 jet back no primary
the cam is the pink on pump and set clearance on set screw to 15 thou like it requests on line
thanks in advance for any pointers!
[Re: CUDA8U]
#1206290
04/04/12 07:30 PM
04/04/12 07:30 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Yea try a 6.5 as it gets you going and if your vacuum is higher that delays opening so a flat spot! may need other tweeks but this is where I would start.
See if you can get an in gear idle vacuum and RPM should be 800 to 850! :-)
Lately people seem to be erroring on the low side for PV's mostly to stop problems with low idle speed and vacuum associated with it then you need to go up! Holley used to put 6.5's in as a rule new and for most performance cars that worked well????
