Re: New Hemi Builds and Swap Thread
[Re: STEFF]
#1205782
05/01/12 12:06 PM
05/01/12 12:06 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
389", more comp, big cam, fixed 6.1 heads.....should be fun!
Offset ground or scat crank ?
Offset ground 6.1 crank....3.68 stroke x 4.100 bore
Nice, is it sleeved? 4.080 has made most people nervous....
[Re: STEFF]
#1205784
09/15/12 04:53 PM
09/15/12 04:53 PM
Posts: 3,425 Toronto
mshred
Toronto
I've got a bit of a stupid question....has anybody used a motor plate on new Hemi yet? It seems like it would be easier to mount that way. I'm no expert, I just read a lot of things when I get bored.
Here's Mine....
Going to ressurect this since I have been thinking about this again...Steff, excuse my ignorance even looking at your pic, but what accessories are you running, if at all? I like the idea of a motorplate if they are being made instead of mounts, but am curious about removing accessories as well like A/C and power steering, neither of which I want
[Re: mshred]
#1205786
05/29/13 03:58 PM
05/29/13 03:58 PM
Posts: 3,874 Smyrna, South Carolina
STEFF
Here's Mine....
Running an Alternator. Kinda' buried under the braided lines in the pic. It's on the pass. side, near k-frame.
I made the motor plate, using a jig saw and drill press. Not hard to do. I did use aluminum tooling plate though, which is finished on both sides. Saved me from having to mill the plate flat for sealing surfaces. I don't have a mill yet.
New motor also has my oil pump mounted to it. I'll post a pic of the new plate and motor later.
[Re: PlumCrazyChris]
#1205788
06/24/13 06:53 PM
06/24/13 06:53 PM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
Bump, anyone having header clearance problems with their 3G Hemi swap?
I'm putting a truck 3g in my Challenger. Its in and about ready to start, but I'm having header clearance issues. I've got TTI headers and Polylock mounts. My headers are pointing downwards too much under the car significantly reducing my clearance.
I'm also running a A500 trans, which is what I'm thinking is causing the motor to be tilted back too far pointing the headers downward.
I've had to do a little pounding to get clearance in a couple of spots, but it tucks up in the tunnel pretty good and doesn't appear to hang low at all. I'm about ready to drop the trans again and pound the crap out of the tunnel to get it up in there more. But before I go to all that trouble, I wanted to know if you guys are having the same issue with headers pointing downward at the outlet?
I think the 5.7 just looks like its leaning back toward the firewall more than stock smallblock/bigblocks in general, from all the pics I've seen.
Anyone have a similar header clearance problem?
I can't comment on header clearance (as I welded my own), but I can say my motor is tilted back more than I'd like. I've also got a tko600 Keisler kit, though.
What do your angles look like? I understand 1.0-1.5* is ideal, .5* is min, 2.0* is max for racing according to Mark Williams, and 3.0* is max according to Spicer. I'm thinking my front u joint is around 2.5* operating angle.
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: mshred]
#1205789
06/27/13 08:45 AM
06/27/13 08:45 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
This is mine - 6.1 crate into an Aussie A body - carb induction. MSD Harness 88864 $185 MSD 6013 spark controller $475 Mounts - TTI - MM57A, $140 (These are rubbish btw and require significant re-working) MP flex plate adapter - P5153753 $85 Jeep Alternator,AL6475X, Alternator 4896805AC or Denso 11113 $225 (Rebuilt) Sump - MIL31000, $205.00 Pick up - MIL18331 $75.95 Dipstick and Tube - MIL 22064 $58.95 Oil plate Adapter - MIL 21566 $34.95 Oil Pan bolts - MIL-85025 $11.95 Oil Pick up stud - 6506333-AA $2.50 Oil Stud Nut - # 6502756 $1.90 Bearing Cap Bolt - 06506272AA $3.70 Oil filter block off TTI - PN 0200-FBP $68.00 Intake gasket $49.00 Indy Modman Manifold $490 Electric Fans $300 Champion Radiator - $240 St & Perf P/Steer delete pulley- $188 Street and performance Headers $673 Plugs LZTR5AIX-13 $101 Belt tensioner 4861277AD - $30 Dayco Tensioner Bolt- $7.95 Dayco tensioner - $24.00 Idler Pulley - $27 Idler pulley bolt - $2 Gates Hoses 25526 (13) 25527 (15) - $30 Lokar Trans dipstick - $55 Lokar Acc cable - $64 PSI Valve springs - $300 (Check the LX forums why these need changing) ![](http://i467.photobucket.com/albums/rr34/TheRatPatrol/Diary%20of%20the%20Rat%20Patrol/The%20Hemi%20Years/20130617_184008_zps32a85466.jpg)
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
