Re: so wich rear main seal is better
[Re: bigblockbryan]
#1205078
03/28/12 01:28 PM
03/28/12 01:28 PM
Posts: 18,160 Mass
DAYCLONA
Mass
i bought a rubber one last year put in my 440 and now i saw a some oil. under my one buddy told me just go back to a cork style
I think your Buddy means "rope style"...IMHO, it's how the seal journal on the crank is finished, if it's smooth, rubber, if it has serations/knurling finish, rope....if your installing rubber, offset the install, so the the mating edges are not flush with the parting line of the cap, have it so that each cut edge protrudes into the opposing journal ends of the parting line,...if your using rope, then ya, you have to flush the seal ends to the parting lines of the crank/block journal, and the rear seal cap
