Horn ring removal on '69 Coronet #120482
09/14/08 01:34 AM
09/14/08 01:34 AM
Missouri, U.S.A.
JSSuperbee Offline OP
Missouri, U.S.A.
I read the archives...but the procedure doesn't work. The column is out of the car. I've pushed and twisted, and otherwise tried tugging in every direction to the point I'm afraid I'm going to bend or brake something. Anybody know of a trick to get this thing off?
James Stinebaker
Re: Horn ring removal on '69 Coronet [Re: JSSuperbee] #120483
09/14/08 02:03 AM
09/14/08 02:03 AM
Colorado
spk2go Offline
spk2go  Offline
Colorado
which steering wheel do you have?
Re: Horn ring removal on '69 Coronet [Re: spk2go] #120484
09/14/08 02:10 AM
09/14/08 02:10 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If you have the wheel with the round plastic emblem in the center of a triangular pad, use a small srcewdriver & carefully pry the emblem out & you'll find a 7/16 bolt ...
Re: Horn ring removal on '69 Coronet [Re: 1_WILD_RT] #120485
09/14/08 11:52 AM
09/14/08 11:52 AM
WOODGRAINWHEELS.COM Indiana
plumbeeper Offline
plumbeeper  Offline
This is a 70 B-body wheel but the 68-69 is the same as far as how it assembles. After you remove the hidden 1/4" bolt (takes a 7/16" socket) then you will need a steering wheel puller to remove the rest of the wheel.
Re: Horn ring removal on '69 Coronet [Re: plumbeeper] #120486
09/14/08 01:14 PM
09/14/08 01:14 PM
Missouri, U.S.A.
Missouri, U.S.A.
Yep....thats the wheel I have. I'll try picking that Dodge plastic logo out of the center and see what's under it....Thanks guys.
James Stinebaker
Re: Horn ring removal on '69 Coronet [Re: JSSuperbee] #120487
09/14/08 01:17 PM
09/14/08 01:17 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The bolt that holds it on is what you will find . Be careful picking it out the emblem damages easily
