A-body exhaust on an F-body? #1204362
03/27/12 01:09 AM
03/27/12 01:09 AM
PA
W
w7smallblock Offline OP
W
PA
I was looking under my Aspen and my Duster and think the a-body exhaust kit will fit the F-body. Has anyone put an a-body exhaust kit on an F-body? If so what problems did you run into?
Re: A-body exhaust on an F-body? [Re: w7smallblock] #1204363
03/27/12 01:51 AM
03/27/12 01:51 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
If your going to run duals it'll have to be a late 77 + up F body and you'll have to move the fuel tank to the right a bit to make room for the left tailpipe. I dont believe the 76-early 77 tank can be moved.
Since its a bent bar car your header choices are pretty decent.
Re: A-body exhaust on an F-body? [Re: nomore65BelvJim] #1204364
03/27/12 02:01 AM
03/27/12 02:01 AM
PA
W
W
PA
Yes you are correct the78-80 have different tank and can be slide to the pass side to get the duals on 76-77 can't move the tank. By the way mine is an 80
Re: A-body exhaust on an F-body? [Re: w7smallblock] #1204365
03/27/12 02:43 AM
03/27/12 02:43 AM
lots of 1 year only parts on an '80.
I've gone through a couple dozen F's, including 2 80's
Re: A-body exhaust on an F-body? [Re: nomore65BelvJim] #1204366
03/27/12 05:20 PM
03/27/12 05:20 PM
PA
W
W
PA
