Re: Steering coupler question [Re: Rick_Ehrenberg] #1204349
04/27/12 12:28 AM
04/27/12 12:28 AM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Absolutely correct. Not really dangerous, but once you snap the nylon breakaway pin, or trash the upper bearing, you've set yourself up for lots more work and parts-chasing.
Flaming River's setup works fine with their column (only), because it is a close-tolerance collapsible deal with no breakaway pin.
Rick
Rick, there has to be cheap-o factory alternative out there. My coupler body was actually worn so no amount of rebuilding was going to save it. I don't care if it's a brand-x fix, I want something cheap that works. And that stupid crimp cap always sucked. I'm swapping from power to manual on a 64 b-body so I'm open to suggestions if you come up with something in varying lengths.
Re: Steering coupler question [Re: Montclaire] #1204350
04/27/12 12:55 AM
04/27/12 12:55 AM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Take a peek at a steering coupler for a 76 jeep cj. It does come in a 3/4, 36 spline version, which I believe is the same as many mopar manual boxes. It has a very similar design, giving the desired fore/aft movement, and you can get the whole coupler for $36 or better. I'm going to look into it more, if this works I want an article. Lol
Re: Steering coupler question [Re: woody02] #1204351
04/28/12 12:27 AM
04/28/12 12:27 AM
southern Idaho
moparcyco Offline OP
southern Idaho
hey killerbee...i have a chally as well with the same sloppy gearbox. what was the cost to send it out and rebuild?also is it being built to stock specs,or are they giving it a firmfeel upgrade? thanks
I went with a stage 2 box.Pricing is on there website I believe $329 shipping is probably what will get you though.Im pretty close to Washington so it was only $10 one way.
