no spark from distributor #1204185
03/26/12 09:52 PM
03/26/12 09:52 PM
Frankenmuth, Michigan
Beazly464 Offline OP
i'm getting no spark from the distributor when I disconnected the connector to the pick up plate there is spark I replaced the pick up plate but still not getting any spark not sure what to do
Re: no spark from distributor [Re: Beazly464] #1204186
03/26/12 10:30 PM
03/26/12 10:30 PM
Can you sub in an ECU & ballast from one of your other cars?
Re: no spark from distributor [Re: RapidRobert] #1204187
03/27/12 11:55 AM
03/27/12 11:55 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
What kind of setup are you running? All I know so far is not points, so a 2 wire distributor.
Re: no spark from distributor [Re: Beazly464] #1204188
04/02/12 10:08 PM
04/02/12 10:08 PM
Got it. The ECU wasn't grounded good enough to the frame, the bolts must have came loose. Used slightly larger ones
