Torque converters with O/D or tall gearing
#1204103
03/26/12 08:35 PM
03/26/12 08:35 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I just added a Gear Vendors to the Charger to tame the 4.10 gear for highway cruising. The rpms now equal a 3.23 when in overdrive. I have a 440/493 with 10.8 to 1 ratio, Edelbrock heads, the MP 292/509 cam and TTI 2" headers. The converter was locally built, it is 9 3/4" and estimated to be a 3000 stall. I'd say that the estimate is pretty close to that. The PROBLEM? While at cruise speed, the engine runs UNDER the stall speed and feels lazy. The 4.10s have a whine and I want to swap in a known good 3.91 SG chunk, but that would make the cruise rpm even lower. Normally that would be a good thing interms of improving MPG, but as it is now, the trans slips up to and above 3000 rpms before feeling much acceleration. I'm in a tough spot though. I want LESS stall speed to improve freeway performance, but it needs to have enough stall to keep the car from being a slug from a dead stop. I don't plan to drag race the car much, but I DO like to boil the hides on occasion. I guess this leaves me in a tough spot, since the MP '509 cam seems to like a looser converter. I do intend to move up to a Comp 285 cam. I ran them before, but both wiped a couple of lobes within 500 miles. Since then I heard that they have improved their products. Also during that time, I learned more about proper oils to use to avoid failure. So in summary, Does anyone have advice or experience with this? I'd like to lower the stall to 2300-2500 but would like to hear from others. Thank you, Greg.
Re: Hi stall converters with O/D or tall gearing
[Re: Kern Dog]
#1204104
03/26/12 08:55 PM
03/26/12 08:55 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Sounds like you want a lock-up converter. We use to call the old GM lock-ups "dial-a-stall" do to certain mods. Maybe something simular for Mopar?
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: Kern Dog]
#1204105
03/26/12 09:10 PM
03/26/12 09:10 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
You have bolted together an pretty odd mix of parts.
The cam will not like to run happily at low rpm but you desire the low rpm for cruising.
Today's answer would be a broader range camshaft profile. Less overlap. Something that will run well, just off idle.
The cruise rpm under stall speed. Again, in a modern car. The answer is a lock up convertor.
I was able to experiment with this with a 518 lock up 4 speed automatic. My conclusion was the manually engaged lock up was more useful at low rpm. I could engage lock up at 1700 rpm and pull 500 rpm out of it. Lock it up at 2500 and it would only pull 200 rpm out of it. At 3000 rpm, lock up vs no lock up was hardly noticeable.
Try comparing you cruising rpm vs cruising rpm on jack stands. What is the rpm difference? Alot says it's really slipping. None means, I wouldn't worry about it.
[Re: Magnum]
#1204106
03/26/12 09:30 PM
03/26/12 09:30 PM
Kern Dog
Granite Bay CA
Thanks for your post, but this sentence wasn't fair or accurate. Take out the Gear Vendors and NOW how does it look? It looks like a pretty common street setup that would likely be a low 12 second car. My goal was to get the rpms down to reduce engine wear and improve mpgs. Can you fault a guy for that? I am aware that the '509 cam is a design that was never intended to be used in a commuter car. As mentioned, I liked the Comp Cams 285 for its street manners and slight increase in power. The theory is that the modern cam wouldn't need to idle at 1000 rpms, and a lower stall converter could be used with it. Thanks for the lock-up suggestions. From what I understand, I'd need to swap additional parts within the trans to use a L/U converter.
[Re: Kern Dog]
#1204107
03/26/12 09:50 PM
03/26/12 09:50 PM
Posts: 9,887 USA
CrAlt
USA
Do you have a trans-temp gauge? I'ed be worried about it overheating.
I have a OD trans in a brand-X car and it has a loose converter and lockup. If I forget to turn the lockup on it gets real hot.
If im on the highway cruising along there is almost a 800rpm difference between on and off the gas just maintaining speed at 55mph.Its just sitting there heating up.. No get up and go until I push on it more.
Click the L/U on and the temp drops off and its like a manual on the highway. Instant response.
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
[Re: CrAlt]
#1204108
03/27/12 03:08 AM
03/27/12 03:08 AM
Kern Dog
Granite Bay CA
THIS describes my situation as well. Accelerating without a downshift feels lazy. I know that it can't be good. I was thinking of the heat that must be generated by that. I have an external cooler mounted in front of the radiator, but no trans temp guage.
[Re: DaytonaTurbo]
#1204112
03/27/12 02:39 PM
03/27/12 02:39 PM
Posts: 1,665 Milwaukee, WI
Prince_Valiant
Milwaukee, WI
I think you'll need to have a new converter built.
This...as a "general rule of thumb" you don't want to have the stall speed of the TC higher than the cruising rpm's in top gear of course...but one way around this is to have a custom stall TC....a good mix would be a 9 1/2" converter that is built "tight" so that there is very little slip at low loads, but as soon as you step on it, it flashes to the desired 3000+rpm stall speed.
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph 1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD) 1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD) 1989 Shelby CSX #500/500
[Re: DARTH V8Я]
#1204117
03/27/12 06:29 PM
03/27/12 06:29 PM
Posts: 2,025 Bucks County, PA
500Stroker
Bucks County, PA
You need to call Frank Lupo's Dynamic converters. http://dynamicconverters.com/news.htmThey will hook you up with what you need. I have a 500 Stroker, 727, Gear vendors with 3:55 rear. I have driven it over 50K miles in 8 years. In 2008 I switched from a Mopar Performance 175K to a custom converter from Dynamic. The difference was night and day. MPG increased by 2. The car idled and took off way better than before. The converter flashes to 3800 when I need it to. No slippage on the highway when cruising at 75 MPH at 2500 RPM. No slippage from a dead stop either. Cruising at 35 mph in OD, punch it, converter flashes to 3800, my 4200 pound car takes off while whipping my passenger's neck back into the seat. The original 509 can be driven on the street. I got 35K miles and over 100 1/4 mile runs on mine with the GV in the car before it wiped a lobe. Went with a little milder cam on the rebuild.
