Removing sticker goo from a dash pad #1203813
03/26/12 11:52 AM
03/26/12 11:52 AM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
There is about a 2" x 4" area on the dash pad of my Dart I recently bought where someone had put a sticker at one time. They removed the sticker before I got the car but didn't bother to clean the decal adhesive from the pad. I would like to know what I should use to remove the goo that won't harm or fade the dash pad vinyl as the pad is otherwise in excellent shape. Suggestions?
Re: Removing sticker goo from a dash pad [Re: 1970RT] #1203814
03/26/12 12:02 PM
03/26/12 12:02 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I have used some wd40 and some rubbing with good results.
Re: Removing sticker goo from a dash pad [Re: mopars4ever] #1203815
03/26/12 12:05 PM
03/26/12 12:05 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
wax and grease remover
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: Removing sticker goo from a dash pad [Re: mopars_1] #1203816
03/26/12 12:06 PM
03/26/12 12:06 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Goo Gone should work also.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: Removing sticker goo from a dash pad [Re: 1970RT] #1203817
03/26/12 01:17 PM
03/26/12 01:17 PM
Missouri
bb74swngr Offline
mopar addict
bb74swngr  Offline
mopar addict
Missouri
I have had good luck with anything plant oil based. I have used what ever was handy, peanut oil, peanut butter, etc. Apply and let set for a while, may have to do it a couple of times. I stay away from petroleum based stuff on my dash. You might give it a try.
BigBlock 74 Swinger
Re: Removing sticker goo from a dash pad [Re: Savoy1964] #1203818
03/26/12 06:34 PM
03/26/12 06:34 PM
MD
floyd Online content
floyd  Online Content
MD
agree
Re: Removing sticker goo from a dash pad [Re: floyd] #1203819
03/27/12 09:22 AM
03/27/12 09:22 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
windex, works great on windows, should work for dash also
