Re: Hughes converters?
[Re: MOPAULY]
#1203792
03/26/12 01:08 PM
03/26/12 01:08 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
Same good experience as Junky. Mine is behind a very mild 440 and flashes 27-2800. My tranny is still full auto and it shifts like a stock converter.
BigBlock 74 Swinger
[Re: StukaJU87]
#1203796
03/26/12 07:11 PM
03/26/12 07:11 PM
Posts: 9,887 USA
CrAlt
USA
I had a off the shelf 904 'Street Master' one and it worked fine for years. Outlived 2 904's behind 2 different engines. At one point I did crack the snout (and broke the pump ears..prob because I was running a Cheeta manual RVB on the street ) and a local converter shop was able to fix it no problem.
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
[Re: Exit1965]
#1203800
03/27/12 01:26 PM
03/27/12 01:26 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
I have one they call the 10" 3000 stall. Flashes at 2800, could be my combo but I expected higher. Other than that, it seems to do the job, having nothing to compare it to.
I read someone else on here (in the race forum) mentioned they picked up 7 tenths by swapping out their Hughes converter for another, that it would slow any car down, but I don't know what the problem was with it.
Yeah, I saw that post too. But then you have other people, like a friend of mine that runs a '70 Chevelle in the low 9's, that won't run anything else but a Hughes. And I've seen other posts that claim Hughes are good converters. So...
