throttle screw not turning on the 1050
#1202650
03/24/12 07:38 PM
03/24/12 07:38 PM
Posts: 8,859 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
Took car to get exhaust put pn it this mon the idle ir too high so i kept backing thev fronts off same amount till no longer touching still ideling to high (2000) so started backing the secondary off lil at a time the back carb turned front is froze solid i had a big screwdriver on it and that baby not budging sprayed so pb blaster on it but so far nothen what the heck ?lol
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: throttle screw not turning on the 1050
[Re: rickraw]
#1202652
03/24/12 08:15 PM
03/24/12 08:15 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
No domnator carbs have a idel screw in front and secondarys all turn except one secondary idle screw
[Re: HEMIFRED]
#1202654
03/24/12 10:57 PM
03/24/12 10:57 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Well id like to get it out with out breaking the boss its threaded into
[Re: toplescuda]
#1202655
03/24/12 11:11 PM
03/24/12 11:11 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
not seeing it giving advice is hard but It sounds like time to pull the carb and get it where you can see exactly what the problem is close up and from all angles.
home of the Sox and Martin Hemi Duster
